Knocking Noise When Changing Up Throught Gears
Old Aug 12, 2009 | 08:35 AM
Smackfiend's Avatar
Default Knocking Noise When Changing Up Throught Gears
Hello there, not too sure if this has been covered but each time I go up through the gears 1-2, 2-3, sometimes 3-4 but rarely 4-5 a knocking noise occurs when I press the clutch and also when I release the clutch on my 2004 S60 D5.
It also happens if I stay in gear e.g. 3rd and come off and on the accelerator.
The top mount has been changed to a harder type by the previous owner (he said it did not knock before the change)
Is there any specific mounts that would also need changing to eradicate this knocking?
Thanks in advance, Ian
Old Aug 12, 2009 | 08:28 PM
There is one between the transmission and subframe check that one as well. It might be bad causing the noise.
mtkpete
2001-2013 model year XC70
Oct 2, 2014 07:09 PM
LOVEvolvos
Apr 24, 2012 10:36 PM
Arsenal6
Mar 12, 2009 02:03 PM
booyaolian
Mar 21, 2008 06:43 PM
itsamac
Apr 10, 2007 12:45 PM
