Metal clacking sound from underneath
Old Jan 1, 2022 | 03:49 PM
JazRay57's Avatar
Default Metal clacking sound from underneath
I have a 2016 S60 Tr5 Inscription. When I am rolling at under 5 MPH and I am next to a solid wall (like in a drive thru or near a barricade, etc) I can hear a steady, metallic clank coming from under the vehicle. At first I thought maybe it was brake-related but I'm not so sure,,. the brakes still have enough pad left. Does anyone have an idea of what would make this sound? It only happens when in motion and it is a definite metal click that correlates with the speed.
Old Jan 8, 2022 | 01:48 PM
yabadabadoo1026's Avatar
i have a similar thing going on. Mine sounds like a rubbing and grinding when i brake suggesting bad pads. I too have put pads on not long ago and took both wheels off and did a visual and all looks good with plenty of pad. I too am clueless and this would have seemed to be a obvious pad issue----------i got grinding but visually no damage on the rotors. I'll be following your thread.
Old Jan 8, 2022 | 03:15 PM
Can you determine if its one or both sides or front or rear? did you do rear pads recently? wondering if the electronic emergency brake needs to be reset. Have you jacked up the car and manually rotated the wheels to listen/feel for any warping in the rotor? How many miles on the car?
Old Jan 9, 2022 | 08:10 AM
JazRay57's Avatar
Sounds more like the front but hard to tell. It's actually more of a clicking sound than a heavy clunk, to be precise, one with each rotation. At any rate I suspect the left rear rotor may be warped, I get a warbling sound from the rear at highway speeds and have a slight wear pattern on the inside left rear tread. I will have it checked soon and post results. Thanks for your reply.
somejd
May 26, 2024 09:39 PM
PetarYanev
Jun 9, 2013 12:02 PM
geealan
Feb 13, 2008 05:07 PM
tupapison
Jul 24, 2006 10:16 PM
androide016
Apr 30, 2006 04:07 AM
