please help me find a way to replace a stop lamp bulb
Old Oct 12, 2013 | 10:48 AM
needhelp's Avatar
Default please help me find a way to replace a stop lamp bulb
I'm receiving a check stop lamp message. And physically the lamp is out on the driver side rear brake light.
Now I'm A NOVICE. I'm not a mechanic , not electrician. I say this so that nobody believes there is a long history with this.
My 2002 Volvo s60 manual states All bulbs in the tail light cluster can be replaced from inside the trunk
Great
then it says The bulbs are located in two separate bulb holders, an upper and a lower. Each bulb holder has a locking pin
Ok? no further reference about locking pin Does that mean the upper holder can be released so that I can replace the stop light bulb?
Old Oct 12, 2013 | 10:50 PM
dsharp's Avatar
Its not really a pin it's 2 tabs that you squeeze and the bulb holder comes out of the taillight . Remove the carpet from behind the lights in the trunk and you will see the two bulb holder assemblies. It's much easier than it sounds in the manual.
Old Oct 14, 2013 | 10:37 AM
needhelp's Avatar
Thanks a lot I found the tabs. Bulb replacement worked fine
needhelp
Oct 12, 2013 05:30 PM
sas80
Aug 11, 2011 08:57 AM
rsylvester07
Aug 12, 2010 12:12 PM
vwbusman
Oct 28, 2009 08:12 PM
chad951
Jan 28, 2008 07:22 AM
