power steering fluid
Old Nov 20, 2007 | 05:57 PM
03silvers60's Avatar
Default power steering fluid
I have a 03 s60 turbo and my power steering a bit low. i looked in the owners manual and it says to add ATF fliud.now i thought that ATF stands for automatic transmission fliud. If thats correct than can you get the p.s fuild at any autozone,napa and advanced auto parts?
Old Nov 20, 2007 | 06:27 PM
Fisher's Avatar
Default RE: power steering fluid
Yes, ATF is automatic transmission fluid. A Dex. III compatible fluid should work. I use the Mobil 1 ATF in my Toyota PS with good results.
Old Nov 20, 2007 | 06:52 PM
Dont use ATF for power steering fluid.
The newer cars take a special fluid.
Vavoline makes one that is compatible.
http://www.valvoline.com/pages/produ...asp?product=22
Get this one.
The ATF will mess the system up.
Old Nov 21, 2007 | 07:28 AM
Fisher's Avatar
The newer fluid will be a light green. I think the ATF should be red. You should be able to tell what was initially in there. If the fluid is light green, then it takesCHF-11S fluid. FCP Groton has a good price on it.
Old Nov 21, 2007 | 08:34 AM
trinitone's Avatar
Volvo switched from ATF to the CHF-11S in 2005 for the S60.
Old Nov 21, 2007 | 10:07 AM
Acutally Volvo switched to that fluid in all 1999 cars.
The S60 got it when they started on 2001.
Old Nov 21, 2007 | 04:04 PM
TECH thanks for your help i almost went and bought the ATF. I'll have to pick up so of that valoline.
Old Mar 5, 2008 | 07:09 PM
mingster's Avatar
Hi Tech,
Looks like Valvoline has discontinued the SynPower Power Steering fluid which I have used in my 2001 S60. I cannot find it in their web site nor local stores. Is there any other compatible PS fluid you would recommend?
thanks
Mingster
Old Mar 5, 2008 | 07:21 PM
We switched to another brand of oil products I will have to get the name of ot tomorrow and give it to you then.
Old Mar 7, 2008 | 01:16 AM
mingster's Avatar
Do you know why Valvoline discontinued the product? Please let me know once you find out the new compatible fluid. Can I just mix it with the old valvoline fluid?
thanks
Mingster
Old Mar 7, 2008 | 09:33 PM
Not sure why they discontinued it.
Wynns is what we are using now but a quick search online doesn't give much.
I will try to get a Number off the bottle on monday.
Was REALLY busy at work today.
Old Apr 14, 2008 | 06:36 PM
patrickbateman's Avatar
Can someone suggest an after market power steering fluid for a 2001 S60 2.4T? Thanks for your assistance.
Old Apr 17, 2008 | 11:08 AM
Delirious's Avatar
ATF as per user manual is to be used upto 2004. 2005 and on is Pentosin CHF 11S or Volvo P/N 30741424
Old Oct 4, 2016 | 07:39 AM
joseph capra's Avatar
Default But there it is, right in the damn owners manual
My owner's manual, which bears the VIN number of my car, a 2004 S60 AWD with 2.5T, under the fluids list only "ATF".
I went to the local dealership and a factory trained service tech of 12 years said "Oh, no, we never put ATF in those cars, we use the Volvo stuff (Pentosin).
I bought my car with a known PS rack leak. I would imagine Pentosin would REALLY leak, (and at 30.00 a quart) After i replace the rack (and probably pump and reservoir), what do I use? Could the wrong fluid have taken out the rack?
This will be my seventh Volvo. It's just stuff like this that makes me hate Volvo.
westsacxj
Jul 13, 2017 07:50 PM
katiejoyful
Dec 12, 2007 04:49 PM
Majki
Jun 10, 2007 12:37 PM
reg
Mar 17, 2005 07:57 PM
Steamroll9
Jan 9, 2005 12:11 AM
