S60 sunrof will not close
Old Apr 11, 2009 | 08:27 PM
Delirious's Avatar
Default S60 sunrof will not close
The sunroof always had issues since we bought the car but now it will not close! Well I managed to close it semi manually but it is now getting much worse to get it done this way. Anyway here is what happens: it will open with a push of the button but then it goes back so far that it clicks like it's skipping a gear, loud clicking noise, then it will not close. I had to play with it, pushing the open button and holding it while it skips and then pushing it to close which then inches it to close back and forth. I started to take it apart, starting at the dome light but not really sure where to go from here.
Any advice/instructions?
Old Apr 11, 2009 | 08:33 PM
Remove the passenger side sun visor and a pillar trim. Then you can pull the headliner down some to get into the motor and maybe remove it for now and close the roof.
Old Apr 11, 2009 | 09:02 PM
Delirious's Avatar
Thanks tech, I got it closed but what is wrong? is it a gear I need to replace? cable?
Old Apr 11, 2009 | 09:07 PM
It might be a cable or the motor might have just come loose.
timtatum
Jan 8, 2025 09:44 AM
AzNick
Dec 15, 2010 10:25 AM
andreop
Nov 7, 2008 09:50 PM
andreop
Nov 7, 2008 07:23 AM
floryed
Jan 26, 2008 07:06 PM
