serge at 1500 rpm
Old Nov 10, 2008 | 12:53 AM
  #21
edgey99's Avatar
Default RE: serge at 1500 rpm
thanks very much for that the info is well appreciated will try all this
thanks
roy
Old Nov 10, 2008 | 01:03 AM
  #22
TIPSP's Avatar
Got Boost?
Any time.
Good Luck
[sm=sorry.gif]tech.
Old Nov 11, 2008 | 11:56 AM
  #23
edgey99's Avatar
hi again spoke to the company that did my exhaust they put on free flow mufflers
so i think it will be some other problem any ideas this ones realy got to me
got a rolling road on the 22nd so that might pic something up hopefully haha
Old Nov 11, 2008 | 03:19 PM
  #24
TIPSP's Avatar
Got Boost?
Could be what tech said: tune up?
you said the last one was in April....How many miles since then. It might need a Tune up
Check the spark plug gaps, make sure they are within spec: Gap0.028- 0.032 in. (0.7- 0.8 mm).
If it is not that....Iguess techcan help you again.
Edit: Tech did metion it is a "normal condition" for manual trans.
Old Nov 23, 2008 | 03:23 AM
  #25
edgey99's Avatar
hi all been to rolling road today my afrs are still showing up to lean, guy says as i fitted it my self the maf needs to be set back up with the ecu has anybody got any info on this .car prob done 4000 miles since last service
thanks roy [/align]
Old Nov 23, 2008 | 06:50 AM
  #26
Im not sure what he means by that. Some cars you need to reset the adaptives but that can be done by removing power to the ECU for 10 minutes.
Old Nov 23, 2008 | 10:07 AM
  #27
edgey99's Avatar
car still running lean maff is new so what other things can i look for
Old Nov 24, 2008 | 03:10 PM
  #28
Vacuum leak or O2 sensor going bad.
Old Nov 27, 2008 | 01:08 PM
  #29
edgey99's Avatar
thanks for that tech will try
Old Nov 28, 2008 | 01:41 PM
  #30
edgey99's Avatar
another question what do they mean by callabrating the maff after fitting a new one
thanks roy
Old Nov 28, 2008 | 01:47 PM
  #31
The computer adaptives need to be reset. Sometimes if they are not reset the computer will think the part has not been replaced and it will set the code again.
Either the special Volvo setup can reset it or alot of times disconnecting the battery will reset it as well.
Sometimes there is an ECU fuse as well if you pull the fuse and disconnect the power to the ECU it should reset it.
Old Nov 29, 2008 | 01:28 AM
  #32
edgey99's Avatar
hi i tech
ive pulled the fuse before but only for 15seconds will try disconecting the battery someone said to touch + and - together for 10 seconds is this correct ,another question (u be getting sick of me asking questions ) i have a custom exhaust fitted cat back with free flow mufflers 2.5 " pipe, now i read in a post that your engine needs to be mapped for the exhaust to work wih the engine is this correct ,do you no ware i can get a (think its a lamda sensor or o2 sensor) for the afrs, for my s60 t5 2001 from and sent here
thanks again tech
roy
Old Nov 29, 2008 | 08:55 AM
  #33
You can disconnect the battery and touch the terminals together for 5 minutes and try that.
You should not need a tune just for the exhaust.
Are you looking for a guage for reading the AFR's?
If so they are like $400.00 or more. You need to have another O2 sensor bung welded into the exhaust and have a wide band O2 sensor installed with the system.
Itsadavisthang
Nov 15, 2013 04:58 PM
bowes73
Apr 3, 2013 01:52 PM
Johnny Volvo
Nov 27, 2012 01:05 PM
pdieni
Jul 26, 2011 08:14 AM
shadowlord
Apr 8, 2008 09:16 PM
