Is a slight engine vibration normal?
Old Dec 2, 2008 | 08:18 AM
gatorbrit's Avatar
Default Is a slight engine vibration normal?
Hi, I have recently bought a 2005 s60 2.5T with 59k miles. Car runs great. When I accelerate at low speeds I feel the engine vibration through the gas pedal. It goes away at higher revs. Is this normal or is it a symptom of worn motor mounts?
Thanks
Rich
Old Dec 2, 2008 | 08:21 AM
Default RE: Is a slight engine vibration normal?
I would inspect the motor mounts.
Old Dec 2, 2008 | 08:23 AM
gatorbrit's Avatar
Thanks, are these something a shade tree mechanic can replace or is it a pro job? If so - any idea of costs?
Thanks again for the quick response!
Old Dec 2, 2008 | 08:31 AM
It might be a torque mount which are easy. The hydrolic ones are more complicated but can be done at a home.
Edit check FCPgroton.com for the mounts.
Old Dec 2, 2008 | 08:41 AM
gatorbrit's Avatar
Are the torque mounts located at the top of the engine bay?
Second question: Can you recommend a "maintenance manual" for this car?
Thanks again!!!
Rich
Old Dec 2, 2008 | 08:50 AM
There is 1 on top and 1 on the bottom.
Look for a program called Vadis. That will tell you everything. Check ebay for Vadis.
Old Dec 2, 2008 | 08:58 AM
gatorbrit's Avatar
I'm guessing this is vadis? Thanks. Rich
http://cgi.ebay.com/ebaymotors/VOLVO...sQ5fLiterature
Old Dec 2, 2008 | 09:02 AM
Yes thats it. You can find it cheaper though.
Old Dec 2, 2008 | 09:04 AM
gatorbrit's Avatar
Great - and thanks again for all your help.
Rich
Old Dec 2, 2008 | 09:11 AM
No problem anytime.
Pej
Oct 14, 2012 08:24 AM
orig_nautique
Aug 30, 2009 06:54 PM
ocean238
Apr 17, 2008 06:20 PM
thullz
Mar 5, 2008 07:11 PM
valiant67
Mar 4, 2008 03:27 AM
