Slow start
Old Apr 10, 2017 | 02:08 PM
Juliunv509's Avatar
Default Slow start
I have a 2001 volvo s60 and when I'm at a stop light and it turns green and I push on the gas all the way it takes a while to start going forward I've changed the shift solenoids and still does the same thing
Old Apr 10, 2017 | 04:46 PM
does the engine rev up and slowly catch (aka "motorboating") or does the engine spool up slowly? If you have slippage - ie road speed doesn't change directly proportional to engine speed, you have a clutch pack problem - the solenoids change the gears. If it doesn't slip just starts slowly, then you may be starting out in 2nd gear - ie similar to winter mode. Did you scan for any stored transmission fault codes? Any flashing STC/DSTC warnings (skidding car icon) or ABS lights? Wondering if your model requires an adaptive reset/training sequence after the repair...
Old Apr 10, 2017 | 04:55 PM
Juliunv509's Avatar
Default I
I haven't driven the car much because I bought it and thought it was the altinator but the goes high in rpm's then it will go after a while and I tried to put it on ramps but the car can't even get up them
Old Apr 10, 2017 | 09:13 PM
stop_at_willoughby's Avatar
It does sound like a transmission slip from you description. Sadly the 01 and 02 were especially notorious for the transmission slipping.
Old Apr 11, 2017 | 05:00 PM
Juliunv509's Avatar
So do I have to get a new transmission
JSO
Jul 22, 2009 06:43 PM
motors
Mar 26, 2009 07:50 PM
chimmychong
Oct 15, 2007 07:29 PM
amikeliunas
Feb 28, 2007 09:17 PM
copycat923
Jan 27, 2006 01:55 AM
