Sunroof Problems
Old Jan 22, 2013 | 07:17 PM
blown03mach1's Avatar
Default Sunroof Problems
My wife's 07 S60 sunroof started making a noise similar to a plastic gear skipping teeth accompanied with the sunroof not wanting to open all the way. Additionally when it would close, it would not sit flush in one corner and you could hear the wind noise.
I found a write up on removing the sunroof so I did last night and here is what I found. On both sides in the track of the sliders was these two broken plastic half-moon pieces. I could not find out where they came from, but once I put it all back together everything has worked perfectly. I think these pieces were jamming the sliders when I was trying to open the roof.
I have no idea where the two pieces came from, but i did notice damage to each of the two accordion pieces at the exact same location. Did these two plastic pieces come off the accordions and if so, what is their purpose in life? Are they required to were I should think about replacing the two accordion pieces.
Two pieces
The two accordions where it looks like something broke off of them.
Thanks in advance!
Old Jan 23, 2013 | 10:06 PM
essar1's Avatar
I've had the same problem with my S60. My accordions ripped from the sunroof, though, so they don't go up and down with the sunroof. I'm pretty sure mine isn't missing those parts, however. Hope there's some replies with solutions! I'd love to take out my sunroof as you did; I'll have to look for that thread.
Old Jan 24, 2013 | 06:40 PM
Here is what I used to take mine out.
Volvo Sunroof Repair « Moving bits around to make noise
Old Feb 24, 2013 | 11:03 PM
essar1's Avatar
Default Thank you
For the great sunroof info. Once the weather gets a bit warmer to work on it I'm gonna try and fix it.
Old Mar 31, 2013 | 02:55 PM
Dray's Avatar
I have a 97 S90 and my sunroof won't come open. It tilts up in the rear like its supposed too. Push the button to open and makes a noise like it is going to open but nothing.
go2sharks
Mar 4, 2014 10:37 PM
poor_red_neck
Apr 6, 2013 10:34 AM
nnamssorxela
Aug 28, 2010 05:26 PM
dan2286
Jun 15, 2009 06:26 AM
backslide
Oct 21, 2006 04:14 PM
