Text message window
Old Aug 6, 2012 | 05:18 PM
treborw's Avatar
Exclamation Text message window
I have a 2003 S60 that I just bought a week ago. I noticed that the text message window isn't working. The LED is lit in the back ground but no messages or driver info comes up. When I scroll through the wheel on the blinker, the manual says that every fifth turn of the wheel should take you back to your onboard info (MPG's, distance driven, etc) but nothing comes up. I can see that when I turn the wheel, the fitfh turn that backlight goes off, and as I continue turning it will come back on but when I push the read button. nothing happens. Any Ideas ?
Old Aug 6, 2012 | 05:19 PM
treborw's Avatar
Text message window not working
Old Sep 2, 2012 | 10:46 AM
patsfn2's Avatar
your Dim is starting to go bad, my is doing the same and I had taken it to the an import specialist and they are going to be fixing it in the next several weeks either by trying to do a reboot and if that doesnt work then they will take it apart to look for loose connections...I hope this helps!!!
Old Sep 4, 2012 | 05:52 PM
MYS6T's Avatar
I am also having this issue . My car is a 03 and the DIm in these cars are know to go and if you remove the dash you can see a paper stick with the part # on it and they are interchangeable but will keep the mileage of the donor car..Read this post http://www.matthewsvolvosite.com/for...hp?f=9&t=29323 and it will give you a better idea of what going on and what you can do about it...
There is also a company called Drivers Information Module for Volvo - Xemodex Inc. | Xemodex Inc.
Old Sep 6, 2012 | 09:01 AM
patsfn2's Avatar
if you want to send your unit away for repair, it will keep the original mileage that it currently has or you can purchase one that has been remanufactured the site is in this thread : https://volvoforums.com/forum/volvo-...-repair-63276/ I hope this helps!
theflemingcrew
Jan 2, 2011 01:44 PM
doublegranch
Jan 30, 2010 08:22 PM
chakrv1
Mar 27, 2009 05:37 PM
tfolkner
Mar 7, 2008 12:12 AM
GeoffC
May 10, 2006 08:33 PM
