Turbo Problem
Old May 19, 2011 | 09:16 AM
Daveb999's Avatar
Default Turbo Problem
Hello all;
I have a 2006 S60 AWD. I have the car at the dealer and they are telling me that the turbo is shot and I need a new one. (They originally were telling me that I needed a new catalytic converter, which is covered by some Federal Clean Air requirement, so I don't have to pay for it.) The total cost (parts/labor) for the turbo unit will be around $2,500. The car has 73k miles on it.
I find it hard to believe that I need a new turbo unit after 73,000 miles. Has anyone else had the same problem? Should this be a warranty item, even though the car is out of warranty?
Old May 19, 2011 | 10:12 AM
jda2000's Avatar
Get a second opinion, turbos rarely fail at those miles unless abused or low engine pressure.
Cat converter is covered for 8 years, unlimited miles, so the dealer probably wants some good money out of you.
Old May 19, 2011 | 04:41 PM
MYS6T's Avatar
You can also find a used Turbo from salavge yard for $250 or so . This is the issue i have found when useing the dealer on used"older" Volvos its always a $1000+ issue with them. Look for a local forgien auto Indy and have them take a look at it. Like what was said i would have a hard time see the Turbo die they are very well made and with out someone touching it there's not a lot that can go wrong with it.
Old May 19, 2011 | 04:51 PM
Typhoon's Avatar
A rebuild of that turbo will be $500 or so. Find an independent workshop and have that done instead.
Old May 19, 2011 | 07:20 PM
Mad Matt's Avatar
I really doubt that your turbo is bad...
What kind of symptoms are you experiencing?
Old May 20, 2011 | 08:23 AM
Daveb999's Avatar
Serious loss of power. The dealer was replacing the catalytic converter, thinking that it was damaged/clogged. There was some rattling noises, so they thought that was the cause.
Once they removed the pipe coming out of the turbo, they noticed that the waste gate was rattling. They said that the problem would get progressively worse.
Old May 20, 2011 | 01:45 PM
Mad Matt's Avatar
What is the wastegate actuator set at?
Old May 20, 2011 | 03:20 PM
Daveb999's Avatar
No idea. Should I ask the mechanic?
Old May 20, 2011 | 06:30 PM
Mad Matt's Avatar
No, I'm just curious if it was just really loose. Do they say it's the wastegate actuator or the wastegate in the turbo it's self? Cause you should be able to replace the wastegate actuator and if it's the wastegate in the exhaust housing, you can replace that by itself. You can find one at a wrecking yard or they come up for sale from time to time.
Really get a second opinion. It really sounds like you're dealer is just trying to make some money off you.
Old May 26, 2011 | 10:43 PM
JoJoDaClown's Avatar
Check to make sure your intake piping is all on and tight. Air filter housing to Turbo, Turbo to Hot side intercooler, intercooler to intake manifold. Good chance of the pipe from intercooler to intake manifold is loose at the intake manifold. Not much to clamp onto there.
lukesvolvo
Oct 6, 2020 01:22 PM
1Gray760T
Nov 13, 2009 08:19 PM
chimmychong
Apr 24, 2008 01:59 PM
volvo_s70
Jan 22, 2008 01:19 PM
toshields
Dec 8, 2007 04:50 PM
