warning lights
Old Jun 12, 2018 | 11:22 AM
Stephen Bell's Avatar
Default warning lights
Hi,
Whilst driving the other day the, SRS Airbag service urgent message appeared along with DSTC Service required message, and the seat belt warning chime started, today along with the previous messages and the seat belt chiming away all the time I am getting City safe service required and No rear seat belts used !
2012 S60 DriveE
Any thoughts ??
Old Jun 12, 2018 | 11:57 AM
you need to go to a Volvo friendly shop to get the fault codes read - that will tell which component is at fault. I'd suspect an ABS (wheel) sensor for the City Safe/DSTC faults. the SRS could be related not sure how - but I'd also give a look around under the seats to see if any of the sensor connectors got wacked.
Old Jun 12, 2018 | 12:02 PM
Im booked into get codes read tomorrow, im getting the feeling that its just one thing setting off all the warnings
Old Jun 12, 2018 | 08:14 PM
hopefully you are right. its been my experience that a single failure can get you a happy meal of codes. Post up what your results are!
Old Jun 14, 2018 | 11:10 AM
Diagnostics are comming back with "no communication"with the airbag module. The mechanic wants to strip down a few areas tomorrow to check all the wiring and connectors are ok, if so then it will be a new srs module.
Old Jun 15, 2018 | 11:45 AM
srs module needed. Can I put in a second hand unit or do i need a new one. quoted over £700 for a new one !! AGGGHHHHHHH
PineTree
Jan 13, 2017 10:27 AM
emsterdw@gmail.com
Jul 24, 2014 08:21 AM
frankiethethumper
2001-2013 model year V70
Jul 18, 2014 10:13 AM
ThorsHammer
Jan 5, 2012 03:52 AM
klphil
Dec 30, 2004 05:41 PM
