'98 s70 t5 with b5244t3 turbo line help
Old Apr 3, 2017 | 12:51 PM
V_T5's Avatar
Default '98 s70 t5 with b5244t3 turbo line help
I had someone swap a b5244t3 in my '98 s70 t5 a few years ago and the turbo lines were a complete hack job. It look like a combination of stock hard pipe, and rubber hose(that I am sick and tired of replacing every couple of months). I am looking to replace these with stainless steel lines if possible.
Can anyone point me in the right direction? Thanks
Old Apr 3, 2017 | 02:45 PM
Smith Volvo's Avatar
Banned
The water lines kind of look stock - although not factory hoses. The oil return pipe is a total hack - I'll agree. Should be a metal line with a special o ring at the block. I would just replace hoses and gaskets and oil line with factory pieces and be done with it.
File Type: pdf
File Type: pdf
Old Apr 3, 2017 | 03:16 PM
V_T5's Avatar
^Thanks for the pdf's!
I'll see if I can source a stock oil return line, but I don't want to keep rubber hoses near the turbo. Bad design by volvo.
I thought this s60 engine used a full hard pipe on the upper coolant line?
Old Apr 3, 2017 | 03:19 PM
Banned
mmm - not sure about this being a bad design - I've never had to replace mine on my 1998 in almost 160k miles
Old Apr 4, 2017 | 06:46 PM
V_T5's Avatar
I think my coolant return may have been cut, the "replacement" hose on there looks longer than the stock ones. I guess I'll pull it off, check for cuts in the line, and measure the gap.
Matt Fowler
Jul 14, 2016 11:51 PM
autoxray
Aug 24, 2014 02:15 PM
Galaxy850Sunny
Jun 23, 2014 04:56 PM
Heath7
Oct 27, 2010 06:45 PM
cm123
May 4, 2009 07:18 PM
