98 S70 will not start - Mechanic puzzled
Old Sep 11, 2010 | 12:03 PM
peterz's Avatar
Default 98 S70 will not start - Mechanic puzzled
took 98 s70 in to a reputable foreign car shop for rear main seal replacement which required pulling trans....
after completion of work it would not start.
They discovered that in the course of the work they damaged the cam shaft and crank shaft sensors... they replaced.....no start....
switched out ignition coil....no start....
towed to Volvo.....they haven't a clue after assessing and now want to charge $95/h to sort out....
Any ideas..
Old Sep 11, 2010 | 04:44 PM
The 1st shop had to mess something up. Maybe they can help you pay the $95 per hour.
Old Sep 14, 2010 | 01:39 PM
donf's Avatar
Help nothing! This is their problem, let them call you when it's ready. You pay for parts.
Old Sep 14, 2010 | 08:43 PM
Maybe they bent the flywheel putting the tranny back in.
Old Sep 14, 2010 | 11:35 PM
2004VolvoS60_Bilal's Avatar
I hope you are not paying for their mistake. If your car was starting up properly before, then it's their fault. Let them fix it, and call you once they have fixed the problem. Don't pay for their incompetency.
Tsebast
Mar 4, 2014 12:34 PM
maximusdecimusmeridius
Aug 8, 2012 11:08 PM
nicky1
2001-2013 model year V70
Jul 23, 2012 05:12 PM
evs
Feb 2, 2009 06:26 PM
TravlAndy
Nov 11, 2007 06:15 AM
