ABS and TRAC
Old Nov 9, 2011 | 12:03 AM
280zxNick's Avatar
Default ABS and TRAC
I bought the car like this I just didnt know why it has been doing this. The Abs and traction control randomly will stop working and then come on again. I've been told that I might just need new rotors but wasnt for sure.
Thanks for the help
Old Nov 9, 2011 | 12:20 AM
SVolvoD4's Avatar
It's most likely your ABS module, it seems these are pretty common to stop working because the high heat. Have your speedo and odometer stopped at all?
Old Nov 9, 2011 | 12:23 AM
280zxNick's Avatar
No both still work fine
Old Nov 9, 2011 | 12:37 AM
SVolvoD4's Avatar
Still probably The module, I don't see how changing the rotors would affect the ABS, seems like that would be just the brake light...but I don't know about thatfor sure. It looks like they're pretty easy to fix on your own if you have a soldering iron. I'm about to do mine.
Old Nov 10, 2011 | 04:45 PM
JRL's Avatar
JRL
That would be definitely the module
Matty Moo on Matthews site repairs them for about $60, can't be beat
Here's his email:
Matt:
pollackm74@gmail.com
Old Nov 10, 2011 | 06:11 PM
SVolvoD4's Avatar
Do you know why the rotors needing to be replaced would do that? that doesn't make sense to me...
Old Nov 10, 2011 | 10:18 PM
280zxNick's Avatar
Only what i was told on a different forum.
280zxNick's Avatar
Here's his email:
Matt:
Thank you for the help
Old Nov 10, 2011 | 10:26 PM
SVolvoD4's Avatar
Huh, well best of luck to you, I have also heard Matt does a great job, hopefully a new module will fix it (it should). Keep us updated on what happens
Old Nov 14, 2011 | 08:48 AM
tr_car_nut's Avatar
Swap the module for $60 (you can also find repair places on eBay). Don't bother trying to fix it yourself it's not worth the trouble. Your going to need a reverse Torx socket to remove it from the brake system (you can get that at Harbor Freight).
dragonwingvolvoc70
Aug 22, 2011 08:00 AM
gabyman97596
Dec 23, 2010 08:59 AM
Peti
Sep 11, 2010 12:48 PM
chef
Jan 10, 2009 02:08 PM
94volvo850
Oct 28, 2005 09:30 PM
