abs/tracs
Old Oct 15, 2006 | 01:58 PM
jayleon's Avatar
Default abs/tracs
I have a 1998 S70 T-5 with about 93,000 miles. Recently, the ABS and TRACS lights have come on simultaneously. this is an intermittent problem, but is becoming more pronounced. A quick review of this bulletin board indicates that the consensus normally is a bad ABS module. (we also have a 1995 850 GLT with about 85,000 miles that curiously developed the same problem at about the same time.)
my Haynes manual for the 95 850 indicates that trouble codes should be stored in the OBD II system to help diagnose the problem. However, when I tried to pull the codes with my reader, the reader indicated that no codes were stored.
I assume may bad ABS wheel sensor could also cause this problem. in other words, I don't want to start swapping parts indiscriminately without a better idea of what the problem might be.
So here are my questions?
1. Should this problem be generating trouble codes. If so, why are none showing up on my code reader?
2. If no codes are stored, what's the best way to diagnose what is causing this problem.
Old Oct 15, 2006 | 02:19 PM
Default RE: abs/tracs
Does your scanner read ABS codes?
If not then you won't see codes.
Old Oct 15, 2006 | 02:34 PM
jayleon's Avatar
No sure what codes the scanner reads. It's an Actron scanner and the manual indicates it reads B, C, U and P codes.
Old Oct 15, 2006 | 02:36 PM
But if you can't get into the ABS module then you can't read the codes.
I will bet it only reads engine codes.
Old Oct 15, 2006 | 02:39 PM
jayleon's Avatar
Okay. So playing the odds, would you go with a reconditioned ABS module?
Old Oct 15, 2006 | 02:45 PM
On the S70 YES.
Look on here there is many places that you can send it and have it rebuilt for $100.00 or less.
At work we do Atleast 4 or more ABS modules a week.
Old Oct 15, 2006 | 03:02 PM
jayleon's Avatar
ok about the s70
Any suggestions about the 95 850? I get the impression that the brake and mechanical systems in the 850's and s70's of those vintages are basically the same.
thanks for your help
Old Oct 15, 2006 | 03:21 PM
Look at the module on the 850 if it is in the same location as the S70 then yes I agree.
But if it is up next to the fluid bottle then no.
You can pull codes on the 850 if it still has OBDI.
1995 was a split year for OBDI and OBDII.
Follow link to pull codes.
http://www.troublecodes.net/Volvo/
Old Oct 18, 2006 | 07:44 PM
veso_ht's Avatar
if u got the actron scanner at oreily it will not read the abs codes. i have it & another actron which specifically reads abs codes & it shows them (i have the same problem with the abs on my s70 and s80) try the cruise control when the lights are on. if the cruise dosen't work then it should be the module for sure. i just send in my s80 one to this guy, hopefully will turn out ok
http://cgi.ebay.com/ebaymotors/Volvo...QQcmdZViewItem
Old Oct 29, 2006 | 04:16 PM
veso_ht's Avatar
put the module back in & everything works ok. all the lights are off, no more codes in computer. the only thing is the cruise control isn't working so i need to email & ask them what's up with that. we'll c how the car does the next few days but so far it's good.
Old Oct 29, 2006 | 11:14 PM
Make sure there is no codes in the engine module.
If there is that could stop the cruise from working.
Old Oct 30, 2006 | 01:09 PM
veso_ht's Avatar
everything works great this morning! i guess it needed time to clear.
Old Nov 7, 2006 | 01:05 AM
dray795's Avatar
where or who can I send my ABS/TRAC module for repair? Is there a list of choices and prices?
Old Nov 8, 2006 | 07:38 PM
veso_ht's Avatar
look on my above posts. click the link to ebay. although the auction has ended, you can email the seller & arrange the deal with him. these guys do a very good job! there's no options to choose from except you can have them send you an already rebuilt unit when they get yours but then it's more expensive. you'r fine to drive the car w/out the module, just be extra cerful.
thanks,veso
paulh
Jan 30, 2008 08:22 PM
Buck
Aug 11, 2006 12:56 AM
rmmagow
Mar 29, 2006 10:28 PM
rpm48
Mar 17, 2006 08:50 PM
vwown3d
Aug 20, 2005 03:01 PM
