Access to s70 headlights to fit R8 lights
Old Feb 18, 2009 | 04:43 AM
carpcatcher's Avatar
Smile Access to s70 headlights to fit R8 lights
Hi, Anyone advise me how easy to get headlight lenses off to fit R8 style light strips. Anything else to take off / out to access them. Would I need new seals etc on refitting. Thanks in advance.
Old Feb 18, 2009 | 02:07 PM
Somthngfrce's Avatar
This is a Huge MOD with the VW mK guys! I have seen a ton and I have seen a few on other 850's. You should be able to take the headlight out easy and then tap on for the LED's.... This has been done http://volvospeed.com/vs_forum/index...&#entry1295363
Old Feb 18, 2009 | 02:08 PM
BTW, post pics if you end up doing this!
Old Feb 18, 2009 | 05:11 PM
S70driver's Avatar
Please don't make them like the OP of that that linked thread. Those look ugly.
Old Feb 18, 2009 | 07:06 PM
Here's a few other examples I have found.
Attached Thumbnails Access to s70 headlights to fit R8 lights-led.jpg   Access to s70 headlights to fit R8 lights-led1.jpg   Access to s70 headlights to fit R8 lights-led2.jpg   Access to s70 headlights to fit R8 lights-led3.jpg   Access to s70 headlights to fit R8 lights-led4.jpg
Old Feb 19, 2009 | 04:02 AM
Being cheeky, can anyone scan and send me the page from Haynes manual re removing headlamps please.
Love to have a go this weekend
Thanks
Old Feb 19, 2009 | 06:36 AM
Default Found instructions on YouTube !!!
Messing around on YouTube, found lots of "HOW TO" items for volvo's, including the following
http://www.youtube.com/watch?v=ieXVC...eature=related this is how to remove headlight assembly from a S70
http://www.youtube.com/watch?v=H-r7X...eature=related this is how to change the lens on a S70
Loads of other stuff related to Volvo repairs on there. Just a simple search.
Hope this helps some people.
Happy hunting
Dave
Old Feb 19, 2009 | 06:49 AM
S70driver's Avatar
It is simple.
1. Open your hood.
2. Unscrew the three 10mm bolts in the back of each headlight.
3. Unhook the wiring harness.
4. Take off the 6 or so clips all around the headlight lens and housing.
5. Your done. It should pop off.
To put them back on reverse directions.
Old Feb 20, 2009 | 07:23 AM
Job done yesterday, neon strips fitted. LOOK GREAT !!
Will post pic's when camera found.
Got to be careful of clips attaching indicator lens when removing from body.
Took 2 hours for first removal, install of neon strip and replacement.
45 minutes for second light.
Old Feb 20, 2009 | 04:56 PM
Cool! Sounds like cake..... I'm curious to see how it turned out.
Old Mar 1, 2009 | 01:13 PM
Still trying to find camera..........
Strips of LED from ebay work out at £25 delivered for 2 x 24cm strips with 1 LED per cm.
These strips are totally flexible, so you can make whatever shape you want.
When you come to fit, the rims of headlight bowls are 'corrugated' edge, and will not glue in place.
Suggest drill small holes in edge of bowls, and cable tie in place.
Tried other methods of fixing, and they slip or move out of place.
Only speaking from experience, not "telling you what to do"........
Old Mar 1, 2009 | 07:08 PM
Sounds cool....How bright are the LED's?
Old May 24, 2009 | 02:57 PM
Hopefully these pics appear on here.
Will also put on my photogallery.
Night photos following shortly.
Attached Thumbnails Access to s70 headlights to fit R8 lights-may24004.jpg   Access to s70 headlights to fit R8 lights-may24005.jpg
Old May 24, 2009 | 03:48 PM
Default Night pic's
Just passed MOT last week.
Advisory that "aftermarket lights fitted"
£300 for rear discs, pads, handbrake pads and drive shaft gaiter fitted.
Attached Thumbnails Access to s70 headlights to fit R8 lights-may24009.jpg   Access to s70 headlights to fit R8 lights-may24010.jpg
Old May 24, 2009 | 04:34 PM
Looks Cool! how hard was it to modify the oem lights? Nice job..
Old May 25, 2009 | 09:41 AM
Simple in the end.
Remove headlight...3 nuts to undo
Remove glass...about 5/6 clips
The worst part is getting the LED strips to stay in place.
I drilled small holes in the edge of headlamp lens,
then used clear cable ties to hold in place
Tried glue initially, but uneven surfaces meant did not stick ! !
Get loads of comments.
Even got stopped twice by the police.......
One of whom only wanted to know where I got from and how much
Perfectly legal, passed MOT last week with blue not white side bulbs
Hope this helps
87 740 turbo wagon
Feb 20, 2014 08:50 PM
ernestawazie
Jul 15, 2013 08:10 AM
Volvolcano
Jun 9, 2013 07:13 PM
VDriver24093
Feb 21, 2011 04:35 PM
basp33
Aug 15, 2009 01:03 PM
