Brake issue
Old Jul 6, 2006 | 05:31 PM
S70ismyfriend's Avatar
Default Brake issue
hey i have a 98' S70 and recently while driving i can feel the brake on the drivers side seem to grab a bit on the rotor but after a while it seems to go away when i get up into 60 - 70 mph and also i have to replace my ABS/traction control module would that be what is causing my brake to grab? because it is putting alot of brake dust on that one rim and i can feel alot of heat coming off it when i get out of my car like its the only brake being used any helpis appreciated thnks
Old Jul 6, 2006 | 09:23 PM
Default RE: Brake issue
Maybe a caliper going bad.
I doubt the module is causing it.
Old Jul 6, 2006 | 09:43 PM
i think they were just changed but ill look into it thnks u dont think the rotors are warped do yah?
Old Jul 6, 2006 | 09:56 PM
If the rotors were warped the steering wheel would shake during braking. Mostly under high speed to low speed braking.
Old Jul 7, 2006 | 12:20 AM
ok it doesnt do that it just seems like the caliper is sticking a bit so ill see if the machanic can take a look at that too
Old Jul 7, 2006 | 09:32 PM
Let me know how you make out.
Old Jul 8, 2006 | 02:23 AM
i took it in today abs module was replaced but it needs to be taken to the dealer to get the lights reset and the caliper on the drivers side was in fact frozen and needs replacing along with brake pads of course and i need the rotor turned oh well least ik what it is now and thnks for the help
Old Jul 8, 2006 | 10:37 AM
No problem.
acpenn
Feb 25, 2014 06:50 PM
Earthfromorbit
Jun 15, 2011 03:14 PM
snpklinefelter
Dec 22, 2009 06:26 AM
greg dake
Nov 30, 2008 06:46 PM
Psaboic
Jun 1, 2006 01:14 AM
