Can't open Fuel tank door on S70
Old Jan 9, 2006 | 09:04 PM
ddriver's Avatar
Default Can't open Fuel tank door on S70
Hello,
Can anyone help me with my problem???? I can't get the Fuel Tank Door open on my Volvo 2000 S70.
Thanks,
Ddriver
Old Jan 9, 2006 | 09:07 PM
Default RE: Can't open Fuel tank door on S70
If you open the tailight access on the side on the turnk. You should see a ring of metal. Then you can pull on it and it should open the door.
Old Jan 9, 2006 | 09:11 PM
ddriver's Avatar
I've been all over the trunk I haven't seen a ring of metal. Is it on the same side of the Fuel Tank Door????
Old Jan 9, 2006 | 09:25 PM
ddriver's Avatar
Not able to find metal ring to open Fuel Tank Door.. I have a 2000 S70
Old Jan 9, 2006 | 09:45 PM
Yes it is on the same side as the door. It is behind the panel in the trunk. You might have to loosen the panel and pull it out to access it.
bschulman
Oct 16, 2018 02:23 PM
guptash
Nov 25, 2008 09:39 PM
the_happy_driver
Jun 26, 2008 12:47 AM
