Car running funny
Old May 15, 2009 | 11:36 AM
volvoski's Avatar
Question Car running funny
I couldn't think of a more generic title to discuss my issue as it could be categorized under a few subjects.
Car: 2000 S70 GLT - 96k miles
Initial Problem: My coolant has been leaking very slowly for about 2-3 weeks. I've topped it off everytime it was low because I didn't have time to investigate. I got around to investigating and couldn't find any leaks, though I suspect it is leaking near the turbo because I can't find anything near upper or front engine area (coolant tank, radiator, etc)
Quick solution: Instead of investigating more or taking it to a shop, I was in an autoparts store and thought I'd try the radiator stop leak product. I put the powder in the coolant tank and topped off with coolant with the heater on high just like the instructions said.
Bigger problem: It has been a day since I used the product and now I'm having the following issues:When accelerating from any speed (i.e. when the RPM's are nearing 3k) I get a loss of power. There is a sound coming from the engine bay area that sounds like compressed air. Its a loud whoosh noise. I assume all turbos have check valves, so I'm thinking it could be that, although I'm not sure why or how the coolant would affect a check valve. Could the turbo coolant lines be clogged? The product says its safe for all applications and materials; and specifically says it wont clog the system. Also after the noise subsides the air smells funny outside; though not inside the cabin from the vents. I also noticed a plume of white (couldnt tell if it had a tint of blue) exhaust smoke while accelerating from a stop. For the record, the engine is not overheating so that isn't an issue.
Proposed proper solution: I plan on flushing (drain+refill) the entire cooling system first and hope that this problem goes away. The car is scheduled for timing belt/water pump in the next 2 weeks, I plan on changing the thermostat at that time as well. I'm not sure what else I need to do if I did contaminate the cooling system.
Your input:
I'm not entirely sure the cooling system is at fault; though its the my most likely culprit since this is the only item that I've changed recently. I will need to know if the turbo has a check valve and if it could be the loud whoosh noise coming from the car. What else could be the problem?
Thanks for your input in advance
Old May 15, 2009 | 07:09 PM
I would check the intercooler hoses for leaks. Sounds like one blew out.
karenwilsonv70
2001-2013 model year V70
Jan 28, 2013 03:12 PM
nuclearseal
Jul 19, 2012 03:29 PM
gordon368
Jun 17, 2006 07:42 PM
S90
Feb 16, 2006 06:07 PM
