dying battery
Old Aug 15, 2009 | 09:20 PM
volvorog's Avatar
Default dying battery
Hi, I own an 850 wagon, but my friend 2 doors down owns and S70 sedan,
He is having his battery die on a regular/not daily basis...this has gone on for months, he thinks its the alternator,,I think there is a low voltage short/ground that is killing it...is there a common problem with this problem with this model...are there certain or probable things to check...He did have it wired for a trailer but that was long ago and he trailers a lot of stuff with it...he can jump it right off with his jumper battery (everyone needs one of these, I use mine for radio control stuff all the time) and it works fine...the only strange part is he says if he turns on the recirculated air it usually kills the battery that night....doesnt make sense to me, but I am asking for him....thanks...Rog
Old Aug 16, 2009 | 04:01 AM
Has he had the battery tested? It could be bad. If so, it could die very easy. How often is the car driven? If not driven that much, a dome light or something could drain it.
Some things get power with the key totally off, the fan should not be one of them. Have him try to operate things with the car off to see if some things are still getting power. Maybe the ignition has gone bad.
Old Aug 16, 2009 | 10:36 AM
blackbrick's Avatar
Take the battery to Autozone they will test it for free
Old Aug 18, 2009 | 11:04 AM
volvorog's Avatar
You know,,the day after I posted this MY battery died no reason,,lots a little hoods around here will break into a car...I cant tell you how many times they killed my Miata battery...but no open doors this time..just turned the motor over twice and gone...it took a charge, I drove it 5 miles, but still took my scooter to work...Rog
Mandy813
Engine & Internal
Jul 31, 2011 11:59 AM
NAS
Dec 4, 2010 09:43 PM
NAS
Dec 1, 2010 02:14 PM
Psaboic
Mar 31, 2008 08:37 AM
blue_boi23
Mar 23, 2008 07:47 PM
