Flywheel replacement on an AWD Auto???
Old Nov 21, 2014 | 04:31 PM
Turk13's Avatar
Default Flywheel replacement on an AWD Auto???
Anyone done this? If so what's the easiest method? Best/cheapest place to get the part?
Thanks in advance!
Old Nov 26, 2014 | 08:48 PM
If you are doing this by yourself without a lift, the motor out is the only real option.
Old Nov 27, 2014 | 11:48 AM
Turk13's Avatar
Would you recommend dropping it out or hoisting it up?
Old Nov 27, 2014 | 12:09 PM
Well, the AWD system complicates the heck out of the already difficult job. I replace a motor in a V70 and simply hoisted the motor up and out. At any rate, it will NOT be fun as a DIY task. If you can afford to hire it out to a Volvo mechanic, do so.
Old Nov 27, 2014 | 01:25 PM
ES6T's Avatar
The AWD doesn't make it that much harder. The angle gear can be removed in an hour (or 15 minutes for a pro on a lift)
Old Nov 27, 2014 | 07:42 PM
Turk13's Avatar
Thanks. Does anyone have any links to write-ups or vids?
Jerseys80
Oct 25, 2009 02:31 PM
trans am
Apr 16, 2009 09:17 PM
brownnb
Jun 11, 2007 10:59 PM
brownnb
Jun 11, 2007 05:09 AM
ProMischiefMaker
Sep 29, 2006 09:16 PM
