Front Suspension
Old Dec 4, 2010 | 06:22 PM
lotusing's Avatar
Default Front Suspension
Long time since my last post. This car just will not stop. I don't know if its my luck or this car is just bullet proof. 165K and only a sensor has gone bad and that is it. My question is that with those miles should I not start thinking about struts? If so, what else is a good thing to change while changing the shocks? I did check for loose ball joints and worn bearings but all is good.
Thanks
Old Dec 5, 2010 | 10:06 PM
You may not need struts/shocks. If the roads in your area are not bad you may not need them. Have you had the PCV system replaced? How about your timing belt?
gtsteve
Sep 11, 2011 08:57 PM
johnvan8
Feb 11, 2007 07:31 PM
branse
Sep 25, 2006 11:10 PM
luckytweaker
May 24, 2006 08:28 PM
ghostriderT6
Apr 7, 2006 12:10 AM
