Fuel Smell after Refueling
Old Oct 19, 2010 | 07:45 AM
tomecsi's Avatar
Default Fuel Smell after Refueling
Every time i fill up my gas tank, the smell of gasoline enters the cabin and lingers for a day or two. Why is this happening? How do i fix the problem?
Old Oct 19, 2010 | 01:39 PM
EEaudio08's Avatar
Not totally sure what the problem might be, but when I started smelling fuel in my S70, I did two things:
1.) Replace the fuel injector seals. (Pretty easy job - took me all of 20-30 minutes.)
2.) Replace the fuel filter. This is probably unnecessary, but I say you might as well, since you're already replacing the injector seals. Seal the deal and improve gas efficiency.
Let me know if that works for you. If you want, I've got some photos from the fuel injector seal job that I can post here.
Old Oct 19, 2010 | 02:05 PM
kennedy759's Avatar
are you overfilling? topping off?
Old Oct 21, 2010 | 05:50 PM
tomecsi's Avatar
Not topping off; stop when pump shuts off. I replaced fuel filter already.
Old Oct 21, 2010 | 09:43 PM
Carrots's Avatar
You smell gas inside the car, after refueling. I'll bet someone changed the fuel pump and didn't get the gasket to seat correctly, and fuel is seeping out, or one of the lines is cracked near the pump. Pull off the plate covering the pump next time you refuel, and see what you see. The pump cover is accessible from under the trunk carpeting.
Old Mar 8, 2011 | 06:43 PM
Okla-by-God-homa's Avatar
We are having the same problem with our '98 S70. The fuel pump has not been touched nor has any other part of the fuel system. This only happens after refueling and only lasts for a couple of days. The tank is not "topped off" and nothing has changed in the tank refueling process from years past. Any ideas now.....I have been wondering about the evaporative cannister system.
Old Mar 8, 2011 | 11:34 PM
gdog's Avatar
I would still ck under the fuel pump access cover like Carrots mentioned; fuel leak might be right there.
After that, then yeah, ck out the integrity of the evap system for leaks; usually that will set a code... any running issues?
djmonty
Oct 28, 2013 06:15 PM
1995Volvo850
Jul 6, 2012 07:30 PM
tomecsi
Apr 11, 2012 12:00 PM
jebb1977@hotmail.com
Oct 11, 2009 05:13 PM
risknet
Oct 28, 2008 09:41 AM
