Headlight replacement
Old Feb 4, 2008 | 07:55 AM
RPMCanes's Avatar
Default Headlight replacement
I've got a driver's side lowbeam light out. Are those easy to replace? What should I replace it with?
Old Feb 4, 2008 | 09:35 AM
S70driver's Avatar
Default RE: Headlight replacement
Yes they are easy to replace. And you should replace it with whatever is the OEM bulb. Buy it at Advanced Auto Parts or something similar. It should be an H7 bulb.
Old Feb 4, 2008 | 10:34 AM
RPMCanes's Avatar
Instructions?
Old Feb 4, 2008 | 11:21 AM
S70driver's Avatar
ORIGINAL: RPMCanes
Instructions?
1. Unlock your car.
2. Open the drivers side door.
3. Pull the hood release lever.
4. Open your hood.
5. Remove the low beam drivers side dust cap. It unscrews.
6. Look inside and you will see that the bulb is held in place with a clip. Don't remove it just yet. There is a black conneter that the bulb is plugged into. Remove this black connecter. You will see two wires coming out of it. Just pull it off, it might be hard to do.
7. Once you have done number 6, remove the clip holding the bulb in place. Then the bulb should come right out.
8. Insert new bulb.
9. Put clip back in place.
10. Reconnect the connector
11. Put the dust cap back on.
12. Start the car. Check if new bulb is working. If so close the hood and your ready to go.
Old Feb 4, 2008 | 12:48 PM
JimKW's Avatar
If the car is already unlocked should he lock it first so he can unlock it?
Just kidding. I have found that when one of my bulbs burn out, it not much longer before the other side burns out too. Might as well buy a two pack and replace both of them.
Old Feb 4, 2008 | 02:41 PM
S70driver's Avatar
ORIGINAL: JimKW
I agree.
My dad has a burned out passenger side low beam and then a few days to a week later the drivers side went out.
slynchy
Apr 4, 2016 07:37 AM
Peter1234
Nov 23, 2010 01:19 PM
spike
Jan 4, 2005 08:14 PM
kevinmcgrath
Nov 24, 2004 07:00 PM
kevinmcgrath
Nov 24, 2004 06:57 PM
