Important / Helpful Information - How To "DIY" Repairs
In an attempt to clean up the sticky situation in the S70 section I have decided to start this thread which will be similar to the 850 DIY sticky thread.
The first thing that every S70 owner should know is that their car is simply an improved version of the '94+ 850. Therefore, you can use a lot of the 850 instructions to take care of most things on your car. This goes for '98 - '00 V70's.
If you are a new owner and/or want to know how to care for your car, READ THIS THREAD ASAP: https://volvoforums.com/forum/volvo-...s-s-v70s-9266/
Here is the 850 DIY sticky thread link: https://volvoforums.com/forum/volvo-...repairs-26114/
Other information:
A/C Evaporator Replacement Instructions.
https://volvoforums.com/forum/volvo-...ructions-1697/
Antenna Mast Replacement
Video: https://volvoforums.com/forum/volvo-...t-video-70067/
Brake Pad Replacement - Front.
Brake pads, front, replacement instructions on a 1998 S70 Volvo, also 850
Brake Pad Replacement - Rear
Brake pads, rear, replacement instructions on a 1998 S70 Volvo, also 850
Buyer's guide. For 850 but will help with the S70.
Buyer's guide - Volvo Forums - Volvo Enthusiasts Forum
Video, Top 5 Things To Check: https://volvoforums.com/forum/volvo-...59/#post363177
Cabin Air Filter Replacement.
Cabin air filter replacement - Volvo S70 1998,
Video: https://volvoforums.com/forum/volvo-...t-video-68686/
Cam Shaft Seal Replacement - Front.
Cam Seals, Front Replacement, 1998 Volvo S70 GLT - Volvo 850 Cam Seal Replacement
Cam Shaft Seal Replacement - Rear.
Cam Seal Replacement, rear, 1998 Volvo S70 GLT - Volvo 850 Cam Seal Replacement
Center Console Removal (for shifter light bulb replacement or lighter socket repair)
Video: https://volvoforums.com/forum/volvo-...l-video-68659/
Compression Test.
Compression Test - Volvo S70 GLT, 1998
Video: https://volvoforums.com/forum/volvo-...0-video-71714/
Dash Switch Light Bulb Replacement.
Volvo 1990 - 2000 Series Dash Switch Light Bulb Replacement Instructions - TechnologyInstructions.com
Dash removal for mounting tab repair.
https://volvoforums.com/forum/volvo-...b-repair-5802/
Video: https://volvoforums.com/forum/volvo-...r-video-72821/
Door Panel Problems.
https://volvoforums.com/forum/volvo-...-panels-51136/
Video, Door Panel Removal: Door Panel Removal
Flashers Blinking and Car Will Not Start:
Alarm Has Been Triggered
Fuel Filter Replacement.
Fuel filter replacement instructions on a 1998 Volvo S70 GLT
Video: https://volvoforums.com/forum/volvo-...highlight=fuel
Head Removal and Installation:
http://www.atthetipwebs.com/technolo...ead_gasket.htm
Heater Core Replacement.
https://volvoforums.com/forum/volvo-...acement-25511/
Inter cooler Install, Front Mount.
https://volvoforums.com/forum/volvo-...-thread-13128/
Info **** Repair.
https://volvoforums.com/forum/volvo-...-repair-26586/
Key Stuck In The Ignition:
Video: https://volvoforums.com/forum/volvo-...96/#post361041
New Volvo S70 Owner - What should I do first?
https://volvoforums.com/forum/volvo-...uestions-9266/
Video: https://volvoforums.com/forum/volvo-...57/#post363175
Oil Cooler Line Replacement.
Oil Cooler Line replacement instructions on a 1998 Volvo S70 GLT
Oil pan o-ring replacement instructions.
https://volvoforums.com/forum/volvo-...ructions-1452/
Owners Manual, On-Line at Volvo Cars.
http://www.volvocars.com/us/top/comm...yourvolvo.aspx
Radio Light Bulb Replacement.
Radio Light Bulb Replacement Instructions - SC-815, SC-816, SC-813, SC-715, S70, V70, 850, 960, S90, V90
Video: https://volvoforums.com/forum/volvo-...58/#post363176
Shifter **** Button Replacement:
Specifications for 1998 S/V 70 series cars.
https://customers.volvocars.com/owne...release_8.html
Other information:
Compression Test.
Info **** Repair.
Thank you for this.. anyway you can point me to something on the harmonic balancers for 2000 s70s cant seem to find much in the s70 section ive read a few different ones but im just a little confused on if its the same process for the 2000s as the earlier models
rspi
Jan 1, 2015 09:33 PM
ac, diy, door, evaporator, instructions, intercooler, mount, panel, reinstall, repair, replacement, s70, speaker, v70, volvo
