my antenna hasnt been going up
Old Apr 22, 2007 | 04:32 PM
volvo4lifeson's Avatar
Default my antenna hasnt been going up
Alright , I have a 98s70 t5 and the antenna hasnt been going up lately and sometimes it will randomly go up.... I tried to lubricate it thinking that may be the problem but it isnt. I guess it is something macanicaly wrong..? i dont know...
Old Apr 22, 2007 | 05:18 PM
Default RE: my antenna hasnt been going up
any1 know???
Old Apr 22, 2007 | 05:40 PM
wow this sight is slow.. nevermind then
Old Apr 22, 2007 | 05:55 PM
S70driver's Avatar
Yeah this site is slow. It is just a fact of life. It is probably the gears. They catch sometimes but not others.
Old Apr 22, 2007 | 07:01 PM
JimKW's Avatar
I have the same problem on both my sedans. Here is a link to directioons on how to chamge the mast. It's a pretty common problem.. I had it done two or three times on my 94 850.
http://volvospeed.com/Repair/antmast.php
Old Apr 22, 2007 | 07:52 PM
thanks man! all have to look over those directions..
Old Apr 22, 2007 | 07:58 PM
is the mast something inside to help power the antenna or......?
Old Apr 22, 2007 | 08:01 PM
do I need to buy that? orr
Old Apr 23, 2007 | 02:50 AM
samadkins29's Avatar
http://antennamastsrus.com/ they have volvo antennas under $20. Great service aswell.
Old Apr 23, 2007 | 05:15 PM
thanks
Old Apr 23, 2007 | 06:06 PM
JimKW's Avatar
The mast is the part that goes up and down. It was $16 at fcpgroton.
Old Apr 28, 2007 | 10:17 PM
myothercarisavolvo's Avatar
I bought my antenna mast and eeuroparts.com for $11.90. ($18.18 with shiping)
If your motor sounds like its working its probably the mast.
You just unscrew the nut around it, pull out the old antenna with the plastic toothed cable. Then have someone inside the car turn on and off the radio to feed the new mast and cable back into the motor. On mine the teeth faced the front of the car.
I couldn't feed it all at once, I had my wife turn the radio on then back off real quick to feed it farther down till it was all the way in. Works great now.
Old Apr 29, 2007 | 10:53 AM
JimKW's Avatar
We tried to put the one I bought from fcpgroton into both of my 850's and it did not fit. It would not go into the hole. So both my antennas are still mess up. The one I bought said it would work on 240, 740 or 850, but it definitely would not work.
Old Jul 5, 2007 | 08:49 PM
sandders08's Avatar
This may be because the leader is broken. The leader is the piece of flexible nylon cord inside the antenna mast, which when moved by the motorized reel, forces the antenna to telescope up or down. Try to check it out, ’coz I have the same problem with my Honda antenna mast, and I’ve tried also to lubricate it but didn’t work also and I find out that it’s not the problem…
Old Jul 6, 2007 | 02:52 PM
ZeFf's Avatar
I thought my mast was broken and it ended up being the worm gear inside the motor that was stripped. I had to buy a new antenna assembly. I got mine on ebay for $100.00
Old Jul 6, 2007 | 05:32 PM
Cambridge Volvo's Avatar
Try giving it some Viagara, that will make it go up ... LOL.
Had the same problem, mine just had a lot of grime and grit on it, causing it to stick, so I pull it all the way out by hand and just gave it a good cleaning, works fine now.
Turkey_Sandwich
May 2, 2012 07:47 AM
bsobo
Apr 20, 2010 08:18 PM
daver80
Jun 29, 2009 03:01 PM
alecw81
Jan 7, 2009 05:22 PM
XSive
Jun 20, 2007 05:15 PM
