No signal ligts on driver side
Old Apr 16, 2019 | 08:16 PM
Jwalker47's Avatar
Default No signal ligts on driver side
I have a 2001 volvo v7o 2.4T. I have replaced all bulbs and switch but still have no signal light on driver side. Please help
Old Apr 17, 2019 | 07:48 AM
did you check fuses? which light is not working - ie marker light or the directional?
Old Apr 17, 2019 | 07:56 AM
Jwalker47's Avatar
Default Fuses
Yes all fuses are good. All lights work except turn signals on driver side
Old Apr 17, 2019 | 07:57 AM
Jwalker47's Avatar
Default Fuses
Even with flashers on rhat side doesnt work
Old Apr 17, 2019 | 09:01 AM
Psaboic's Avatar
Well, if all the bulbs, fuses, and switch check good, it is down to either the flasher unit, bad ground, or wiring. I would suggest finding a wiring diagram for your specific year online and start from there.
Old Apr 17, 2019 | 10:45 AM
sounds like the turn signal flasher relay. You can google for vids to see where it is or reference the owners manual. Check out IPD, FCP Euro, eeuroparts etc for the part number and cost. Should be in the $10 range.
cdubb
Aug 8, 2020 04:48 PM
aser9000
Aug 2, 2019 11:58 AM
ShaunWaves
Mar 12, 2016 08:42 PM
dcjcdc
Apr 10, 2010 02:02 PM
castiron
Sep 30, 2005 09:03 PM
