oil pump noise
Old Oct 29, 2011 | 08:30 PM
fields 100's Avatar
Default oil pump noise
Hi to all,
Finally I have located the source of engine cold start noise (2 min. whine, then abruptly shuts off)-it is coming from the oil pump (with a stethoscope attached to the oil cooler hose) . However, I am not shure what needs replacement- pump,which almost never go bad on these cars (98' T5, 46K), cooling thermostat or just drop the pan and take care of that O-ring on the pick up tube? Any ideas? Thanks.
Old Oct 31, 2011 | 12:10 PM
No idea. Is the oil pressure good?
Old Nov 1, 2011 | 08:03 AM
fields 100's Avatar
Oil pressure is good. I think the sound is being created by the oil thermostat. There might be some oil bypassing through and that may cause this whining. Not shure.Trying to find new stat and replace it. Will post if it helps. Thanks.
nuclearseal
Aug 17, 2022 01:48 PM
majorcode
Nov 4, 2013 06:41 PM
nuclearseal
May 1, 2013 07:01 PM
MattyXXL
Sep 14, 2011 12:40 AM
