PCV system...replace or clean?
Old Jan 21, 2009 | 10:44 AM
RichardR's Avatar
Default PCV system...replace or clean?
I have a 99 S70, non-turbo, 149K milkes. About six months ago noticed oil leaking in the front of engine above the oil filter. Cleaned up the engine to pin point the leak but never saw any more oil. Suspected PCV system leak. Now, same thing, oil leak from same place but only a one time deal. Is it time to replace the PCV system?...or is a good cleaning worth the time and effort? I have never done this before but consider myself a fairly good shade tree mechanic and from what I have read it looks like it is doable. Any suggestions would be greatly appreciated!! Thanks!!
Old Jan 21, 2009 | 11:20 AM
Default RE: PCV system...replace or clean?
I would just replace it if you go that far. You will have everything all apart I would just do new parts to make sure all is good.
Old Jan 21, 2009 | 03:10 PM
RichardR's Avatar
Thanks for the advice! Can you recommemd what parts to replace? Oil trap? hoses? And where to buy. FPC Groton has kits but only up to 1998???
Old Jan 21, 2009 | 03:14 PM
I would buy the vent box,intake gasket,the small hose with the metal sleeve. The rest should be fine. You will need clamps but my list is at work and I am not sure when I will be back there.
peace562
Mar 13, 2015 12:50 AM
nitrosport
Mar 1, 2013 07:43 PM
Dainos
Oct 16, 2009 07:56 AM
