Recently installed brakes make brushing sound when used
Old Apr 19, 2008 | 05:32 PM
danerrr808's Avatar
Default Recently installed brakes make brushing sound when used
Hi, I put over 1000 miles on new brakes (non-OEM pads and rotors), and they work great but make noise. I have read that the brakes will make a brushing sound, especially if they have not been broken in. The sound is a metal on metal brushing soundand can be heard when the pedal is lightly touched. Also, one rotor seems to have slight groves in it like a vinyl record. Would that one rotor cause the brushing sound, and will that rotor wear smooth like the others over more time? Or are these just "noisy" brake parts? Thanks for the help!
Old Apr 23, 2008 | 02:32 PM
miller guy's Avatar
Default RE: Recently installed brakes make brushing sound when used
did you put them on right? it sounds like its a metal to metal contact. you need to get that checked out before you ruin your rotors.
Old Jun 26, 2008 | 03:02 AM
BigAl's Avatar
Sounds like you got the lesser after-market stuff. Probably the semi-metallic pads. The OEM is organic and the rotors are made of a softer metal (but can't be machine/turns).
First check if it was installed correctly, if so try to break them in.
If that's the case, you may need to break them in. To to a parking lot or somewhere safe and slam your brakes as if your life depended on it. That's what I had to do on my brother's jeep, the dealership recommended us to. It stopped the noise.
KonaKula29er
Feb 19, 2012 06:54 PM
hollymight
Dec 3, 2010 06:23 PM
maddox
Oct 11, 2006 08:49 PM
jdbs3
Jul 3, 2006 01:06 AM
projekteg
Jun 22, 2006 03:55 PM
