Running serpentine belt without ac
Old Apr 28, 2024 | 09:07 PM
xperinfe's Avatar
Default Running serpentine belt without ac
Can I reroute my serpentine belt without getting a new ac compressor? I'm aware that I will not have ac but is there any downsides to doing this or not really?
Old Apr 29, 2024 | 08:57 AM
firebirdparts's Avatar
If you can find the size and physically get it on there, it'll be okay. It's a waste of time so long as the compressor pulley bearing is good, and so it doesn't get talked about much. If the compressor is locked up and it still turns on, you can just unplug the clutch.
Old May 1, 2024 | 03:57 AM
dhsyu's Avatar
I was pondering: some Wrangler JK online retailers say "with cooling". Does it intend that there are two distinct serpentine belts? Will that one work on the off chance that a Wrangler JK doesn't have A/C?
192.168.100.1 192.168.1.1
Old Jul 17, 2024 | 02:45 AM
Michael W's Avatar
However, there are a few potential downsides to consider:
  1. Engine Performance: Rerouting the belt may alter the tension and alignment, potentially affecting the performance of other components driven by the belt.
  2. Belt Wear and Tear: Improper routing can lead to increased wear and tear on the belt, causing it to wear out more quickly.
  3. Potential Fit Issues: Finding the correct belt length for a rerouted path can be challenging. Using the wrong size can cause improper tension and further issues.
  4. Resale Value: Modifying the serpentine belt system might negatively impact the vehicle's resale value, as it deviates from the manufacturer's original design.
  5. Other Component Damage: The modification may lead to additional strain on other components, potentially causing damage over time.
Before making any modifications, it's advisable to consult a professional Volvo mechanic to ensure that rerouting the serpentine belt won't cause further issues and to find the correct belt size for the new configuration.
xperinfe
Apr 29, 2024 09:43 AM
slowasf@ck
Nov 13, 2022 05:15 PM
nicjor
Nov 13, 2021 06:51 AM
theresabarnes
Jun 14, 2021 05:26 PM
Jay77
Apr 30, 2013 04:35 PM
