S70 Stuck Crank Position Sensor, 10mm is out, sensor won't budge
Old Jan 31, 2026 | 08:17 PM
Oilinmycoffee's Avatar
Default S70 Stuck Crank Position Sensor, 10mm is out, sensor won't budge
Hello everyone,
I am in a jam. I am chasing down a crank no start after sitting for 5yrs.
New gas, gas filter, plug wires as they cracked when checking the gaps. The gap had increased to .42 regapped them. Now I want to check the crank position sensor. I was able to remove the 10mm, no problem, but the sensor won't lift up and out. has anyone been able to remove a stuck crank position sensor and still be able to test it. It just won't lift off the engine.
Psaboic
Nov 22, 2023 08:26 AM
01_fast_ride
Mar 26, 2023 08:17 AM
jonqu
Sep 4, 2013 12:45 PM
Patriq Backlund
Jan 16, 2009 09:38 AM
Beardog
Sep 23, 2007 07:35 PM
