Shift Lock Fuse Problem
Old Aug 18, 2009 | 02:53 PM
daironman's Avatar
Default Shift Lock Fuse Problem
The fuse for the Shift Lock/Cruise Control keeps blowing about every 3rd time we start the car and put it in gear. We use the manual unlock button, but the Cruise Control is also attached to this fuse. Any ideas or help on the possible issue. I haven't torn the console apart to check the solenoid plunger or the brake switch yet...
Thanks!
Old Aug 18, 2009 | 07:24 PM
What year is the car?
Old Aug 18, 2009 | 07:29 PM
daironman's Avatar
its a 1998
I replaced the micro switch about a year ago....so I had the whole console tore apart to figure that out...tested the solenoid...and brake switch, but at the end of the day, it was the micro switch...now just trips the fuse every second or third time starting/putting in gear...
Old Aug 18, 2009 | 07:40 PM
Maybe the solenoid is bad.
I would remove the console and remove the solenoid and micro switch and see if it keeps blowing.
Old Aug 20, 2009 | 09:18 AM
daironman's Avatar
Yeah...I guess i'll have to do that! Thanks!
sherwood112
Sep 22, 2019 09:20 AM
mischief4l
Sep 2, 2008 07:13 PM
dkbmx8485
Oct 19, 2007 12:43 PM
gobaer7
Sep 1, 2006 09:22 PM
TedP
Dec 8, 2003 01:49 AM
