synthetic oil?
Old Jul 26, 2010 | 07:03 PM
dangake's Avatar
Default synthetic oil?
Hi folks! I am new to this site but a life-long Volvo owner. I recently purchased a 2000 S70 with 74K miles. I hope to keep it for a LONG time. I was wondering if anyone has any advice about synthetic oil for this car? Thanks!
KDS
Old Jul 26, 2010 | 08:29 PM
elcs70's Avatar
absolutely you should use fully synthetic. personally i use Mobil 1 and have never had any problems. also amsoil is a good synthetic. how did you find one with only 74k?? what a deal. if it is turbocharged, i would also recommend you use premium gasoline to help prolong the life of your vehicle. and finally, if you are handy with a wrench i suggest you change to synthetic transmission fluid and synthetic gear oil.
Old Jul 27, 2010 | 12:53 AM
milloreeri's Avatar
Synthetic oil is a lubricant composed of chemical compounds that are artificially using chemically modified components of crude oil rather than whole. Synthetic oil is used as a substitute for refined lubricating oil for use in extreme temperatures, and it generally gives excellent mechanical and chemical properties of those found in traditional mineral oils.
Old Jul 27, 2010 | 11:49 AM
xxblindxx's Avatar
i use it, works good
Old Jul 27, 2010 | 05:09 PM
Dealer_Tech's Avatar
Cheap way to keep your engine clean. Change it every 4k-4500 and you shouldnt ever have a lubrication problem.
BenHur
Sep 8, 2015 09:29 PM
Arsenal6
Apr 26, 2009 02:34 AM
aruizdelhoyo
Engine & Internal
Jan 15, 2009 09:26 AM
Mnvolvo1
Mar 25, 2008 08:42 PM
Viraaj
Nov 11, 2006 01:23 AM
