Trans Problem??
Old Jan 17, 2009 | 10:01 AM
srhpunk26's Avatar
Default Trans Problem??
Got in my car this morning and started to drive to work and the car wont aceelerate over 25 MPH. It seems like it might be a transmission problem. Anyone have this issue before????
Old Jan 17, 2009 | 10:11 AM
Default RE: Trans Problem??
Is the up arrow flashing?
Old Jan 17, 2009 | 10:25 AM
srhpunk26's Avatar
No it wasnt
Old Jan 17, 2009 | 11:10 AM
It might be tranny or motor related. But usually if it is tranny related the arrow will flash.
Old Jan 17, 2009 | 11:45 AM
S70GLT's Avatar
I had a similar problem with my 93 850 glt; it would stay in a low gear and not want to shift out - did this until the car was thoroughly warmed up about 10+ minutes and turned out it too was the start of serious problems with that car. (thought it was just a trans. fluid leak at first and yes this was th cas, but only masking bigger problems) looked around in some classified and found a 98 s70 for 5k with 94,000. i was thankful for sure.
make sure you check the trans fluid and make sure the seals are not cracked and leaking.
Old Jan 17, 2009 | 02:34 PM
W35's Avatar
W35
I had this issue in a 92 Ford Taurus, which ended with replacing the transmission. Now since its a completly different vehicle, things may be different for you.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
