Transaxle oil
Old Nov 24, 2012 | 12:00 AM
HeadDragon's Avatar
Default Transaxle oil
I see no spec for it it really looks like engine oil. My shaft seal is leaking and I can't fix it yet.
So where does the transaxle get it's oil from?
Old Nov 24, 2012 | 09:15 AM
The transmission. Dex/Mec III.
Old Nov 24, 2012 | 11:06 AM
HeadDragon's Avatar
Okay the reason I was asking it did not look like Automatic Tranny fluid. I guess I need to flush my tranny.
Old Nov 25, 2012 | 08:35 PM
Lifesgoodhere's Avatar
AWD or FWD?
If AWD you need special fluid. Forgot the spec at the moment, but its expensive.
Old Nov 25, 2012 | 09:16 PM
HeadDragon's Avatar
FWD on unemployment so money is tight to repair the car.
Old Dec 1, 2012 | 02:53 PM
DEX III
Its the transmission, not the transaxle, they are one unit.
On AWD models you have "angle gear" which transfers power also to the rear axle. The AWD also have different transmission which requires special lubricant.
Old Dec 1, 2012 | 02:57 PM
I use the cheap Wal-Mart stuff and do the 3 drain/fill method.
stevejanosik
Nov 18, 2008 09:53 PM
petes99xc
Apr 17, 2008 09:02 PM
fredeuce
Sep 23, 2007 05:51 AM
fredeuce
Sep 19, 2007 02:01 AM
satchmodog
Nov 29, 2005 12:11 AM
