Vibrating in gear on cold starts?
Old Dec 13, 2005 | 06:39 PM
AaronD81's Avatar
Default Vibrating in gear on cold starts?
When it's cold outside my GLT idles louder than normal and vibrates more as soon as I put it in gear (automatic). It drives fine, starts right away, and everything else works great other than this small annoyance. As soon as I drive it for even 2 minutes it stops doing it. I've read engine mounts go bad, but this doesn't seem to be the problem. Any ideas?
Old Dec 13, 2005 | 08:51 PM
Default RE: Vibrating in gear on cold starts?
How about tune up stuff has it been done lately?
Old Dec 13, 2005 | 09:22 PM
AaronD81's Avatar
I bought it about a month ago from a woman who was the original owner and took it to the dealer for EVERYTHING. I checked the records and everything looks up to date. Can you be more specific about "tune up"? The car runs perfectly if I leave it in park, it just vibrates more than usual when I put it in drive but don't actually drive.
Old Dec 14, 2005 | 12:02 AM
Spark plugs, Fuel Filter,Throttle cleaning,Wires,Cap,Rotor.
You might also want to check the front engine mount on the right side of the car.
Old Dec 14, 2005 | 11:55 AM
AaronD81's Avatar
This morning my windshiled was frosted so I started the car and started scraping, within 20 seconds of starting the noise went away and it was fine. Is there something you listed that would go away so quickly? I'd like to give my mechanic something specific to look for because for him to hear what's happening I'd have to leave the car over night and that would be a huge pain for something that's not really a problem.
Old Dec 14, 2005 | 09:15 PM
He can inspect all of the Above.
Does it make a squeeling noise at all?
If so have the timing belt and tensioners and idler looked at.
Old Jan 26, 2006 | 07:01 PM
AaronD81's Avatar
Update, I changed the timing belt, water pump and accessory belt and the noise went away. I have no idea why but it did.
Old Jan 26, 2006 | 09:56 PM
The idler or tensioner pulley might have been bad.
winston901
Mar 11, 2012 12:51 AM
KatieK
Nov 11, 2010 10:29 PM
Kiss4aFrog
Apr 7, 2010 03:06 PM
Berwyn
Feb 9, 2010 11:05 PM
96850urbo
Apr 9, 2009 01:33 PM
