window control switch
Old Jul 29, 2006 | 07:35 PM
Jim_Penrod's Avatar
Default window control switch
Does any one know how diffacult it is to change the switch in the whindow controler driver's door?
I think that the switch has gone bad. The windows quit working, so I checked the fuses and they all seemed ok, so then I tested the switch again and heard a "shorting" sound and a little smoke come from the switch. I am thnking the switch has a short. Any help or sugestion would be great.
jim
Old Jul 29, 2006 | 09:38 PM
Default RE: window control switch
Master window switch is bad.
You can use a small hook tool and pull it out.
But you have to replace the intire switch assembly.
Old Nov 2, 2007 | 06:29 PM
dkbmx8485's Avatar
Where would be the best place to buy another one? Would you suggest an OEM? I want to get one from www.switchdoctor.net but I am skeptical. They claim to use better materials than original switches and they are only $90. Any feedback is appreciated. Thanks.
Old Nov 2, 2007 | 07:04 PM
I have seen some aftermarket switches and don't like them at all.
I would say go OEM.
Old Nov 3, 2007 | 07:26 AM
JimKW's Avatar
Erie used Volvo parts sells them four $65 and gives a lifetime warranty. That is the price they gave me for the 850. I ended up buying one from a guy on volvospeed.com though for $55.
Old Dec 28, 2007 | 10:13 AM
Switch Doctor's Avatar
Hi, I just noticed this thread and I want to clarify that I'm not touting the aftermarket switches I stock as superior to OEM in any way -- but my lifetime warranty IS better than the standard 12 month OEM warranty. The aftermarkets are designed to be virtually identical in appearance and function. I have detailed installation instructions available to anyone on my site: https://www.switchdoctor.net -- it's an easy job that can be done in minutes!
bennyd20
Sep 23, 2011 07:34 PM
SUNBEAM64
Aug 21, 2010 09:58 AM
850GLTWAGON
Nov 21, 2008 04:14 PM
bigld
Jan 2, 2006 08:52 PM
