wont shift into 3rd
Old Oct 18, 2010 | 07:32 PM
freq's Avatar
Default wont shift into 3rd
I was test driving a 98 s70 yesterday. It's an automatic. When I put it in sport shift mode and floor it, it pulls hard to ~65 mph, then it wont shift into 3rd. If I let off the gas when it gets up to ~65, then it shifts into 3rd.
Any ideas what the problem could be?
Old Oct 18, 2010 | 08:06 PM
Carrots's Avatar
well... the transmissions on these car sometimes get a bit of gunk in them that will cause abnormal/ harsh shifting. A manual (don't pay a shop to do it using the rip- off machine) flush usually does the trick. I'd get it checked out for sure, though, before buying the car. Sport shift mode DOES hold out the shifts longer, and RPMS will get pretty close to redline if you have it floored in that mode. If it shifts okay otherwise, it may only need a flush. There's instructions on how to do it around here, and all you need is a piece of vinyl tubing, a couple clamps, a drain pan, and lots of fluid. Again, if this is a car you're looking at buying, have a trusted mechanic- preferably a Volvo specialist or a Euro specialist- look it over first, and at minimum, use this as a bargaining chip, though if the trans itself is on its way out, that's a "no buy" unless the owner is willing to pay for the work.
sadielee
Nov 24, 2020 07:39 AM
Shaq101
May 3, 2016 04:32 PM
Vagn
Dec 23, 2014 03:26 PM
jnduke
Oct 8, 2010 09:17 PM
bigT1888
Apr 27, 2010 12:47 PM
