2000 S80 T6 2.9 re & re thermostat
Old Jan 27, 2011 | 07:35 PM
Seeharper's Avatar
Default 2000 S80 T6 2.9 re & re thermostat
looking for details on re & re of the thermostat
Old Jan 27, 2011 | 09:54 PM
Volvo_n00b's Avatar
Default Here ya go. 2000 S80 T6 2.9 Thermostat removal and replacement.
Replacing the thermostat
Removing the thermostat
Remove
-the clamp holding the return hose for the power steering
-the screw holding the engine stabiliser brace to the bracket on the engine
-the screws holding the engine stabiliser brace to the suspension turrets
-the engine stabiliser brace
-the expansion tank cap.
Raise the car. Remove the lower splashguard.
Position a container under the engine drain ****. Drain the coolant.
Close the ****.
Install the lower splash guard.
Lower the car.
-the plastic hoses between the turbocharger (TC) / charge air cooler and the air cleaner (ACL) / turbocharger (TC). Applies only to B6xx4T engines.
Lift up the servo reservoir and place it on top of the engine.
Warning! Seal the cover for the servo reservoir. Check that no oil leaks out.
Servo oil is highly inflammable.
-the screw for the front timing belt cover. Applies only to B6xx4T Cars with chassis number 203779- see Timing cover front, replacing
-the timing belt cover. Use a weatherstrip tool.
-the thermostat housing cover
-the thermostat.
Installing the thermostat
Note! Clean all mating surfaces. Ensure that no dirt enters the fluid ducts.
Install
-the new thermostat
-the cover of the thermostat housing with a new gasket. Tighten to 17 Nm
-the front timing belt cover. The mudguard over the right drive shaft boot may come loose. If this happens, secure it from underneath
-the screw for the front timing belt cover. Tighten to 12 Nm. Applies only to B6xx4T Cars with chassis number 203779- see Timing cover front, replacing .
-the servo reservoir. Check that the hoses are correctly positioned
-the screws holding the engine stabiliser brace to the suspension turrets. Tighten to 50 Nm
-the screw holding the engine stabiliser brace to the bracket on the engine. Tighten to 80 Nm
-the clamp holding the return hose for the power steering.
Carry out a function test
Fill with coolant.
Install the cap on the expansion tank.
Test drive the engine until the thermostat has opened.
Top up the coolant if necessary.
aben132
Nov 12, 2014 10:03 AM
Lab_Rodent
Sep 23, 2010 06:32 AM
poor_red_neck
Sep 22, 2010 08:18 PM
huzzsaba
Apr 2, 2009 05:35 PM
monnetmj
Sep 19, 2008 07:58 PM
