Battery CCA 600 vs 650?
Old Dec 20, 2007 | 09:14 AM
Mnvolvo1's Avatar
Default Battery CCA 600 vs 650?
The original battery is rated for 600CCA.
If replacing with a battery rated for650CCA will this damage the car'selectrical system?
Thanks
JK
Old Dec 20, 2007 | 11:26 AM
team's Avatar
Default RE: Battery CCA 600 vs 650?
no
Old Dec 20, 2007 | 01:50 PM
jks2's Avatar
The CCA is just the number of amps the battery can put out. Not the amount that will be transmitted to the ignition, etc. The voltage sent to each system is regulated. There's really no need to go way above the recommended CCA. The expense goes up and it really isn't worth it.
Old Dec 20, 2007 | 01:52 PM
Mnvolvo1's Avatar
Team,
Thanks for the reply. After I posted that msg I talked with the Service MGR at my dealership and he confirmed that also. After calling around the Volv Dealer was actually cheaper than was NAPA and Sears for a battery. Figure that one out.
JK
Old Dec 23, 2007 | 05:04 PM
master_pre's Avatar
Always go with the most CCA's that you can get within your price range. Those extra amps can never hurt!
Old Dec 25, 2007 | 01:24 AM
zmontgomery's Avatar
ORIGINAL: master_pre
...........especially if you live in an area where it gets cold in the winter
mcfierce
Jul 28, 2014 10:49 AM
white83glt
Oct 20, 2011 03:16 PM
2008_XC90_AWD
Jul 26, 2008 09:36 PM
BuildinAs70
Feb 12, 2008 08:24 PM
volvodriver1339
Mar 24, 2007 03:19 PM
