Brake Fluid Change
Old Sep 14, 2014 | 01:08 PM
Sherry007's Avatar
Default Brake Fluid Change
Hi,
I want to change my Brake Fluid since its never changed.
Volv0 s80 1999 2.9 Non Turbo. 183000 KM
Though I do not feel any problem while braking or any other issue but I do wonder it might at least requires a change after so many years.
Please share any link or instructions how to change it as well which brand or type is recommended. Will surly appreciate.
Thanks
Old Sep 14, 2014 | 01:57 PM
ES6T's Avatar
It should certainly be changed. The recommended interval is every two years or 37,500 miles.
Brand doesn't really matter, as long as it is DOT 4 fluid.
Replacement is just like any other brake bleeding procedure you can find.
Old Sep 14, 2014 | 05:07 PM
Sherry007's Avatar
Thanks ES6T. Another important Q, after all these years when I changed my transmission oil I lost the transmission, how about in this case, everything is working fine as of now but do I have to cautious before making decision?
Could you please guide any exact link or specify the instructions how to change it? how much I need etc. Will surly be thankful.
Old Sep 14, 2014 | 05:23 PM
oragex's Avatar
If the transmission works fine, at this high miles I won't touch to the oil. It will probably work fort he next 50000km without issues.
For the brakes, the only problem will be to release the bleeding nipples. They are all more or less seized, penetrating oil days or weeks in advance help quite a bit. Rear wheel bleeders are smaller in size and if you force them it will shear.
Old Sep 14, 2014 | 06:05 PM
Sherry007's Avatar
Oragex, after searching tons of information, I am still confused about 1999 S80, now they say there is a specific order to bleed LF,RR etc then I do know how to start bleeding the fluid and how long? Will surly appreciate step by step info.
Note: By the way now I know, on few occasions I had to brake suddenly and car did not response as it should "I ignored",normal braking is fine but sudden is not very responsive, maybe due to old fluid.
Old Sep 15, 2014 | 08:31 AM
ES6T's Avatar
One quart of fluid should be plenty. I always flush RR, LR, RF, LF. I think Volvo actually says to do the opposite. It doesn't really matter.
Old Sep 15, 2014 | 09:28 AM
Sherry007's Avatar
Thanks ES6T. How about the steps?
like how long I have to bleed each line?
do I have to keep open the cap of oil tank?
any other caution?
please advise.
Old Sep 15, 2014 | 12:01 PM
oragex's Avatar
Just like ES6T says, with one quarter you shoud be fine, even less if you don't manage to loosen the rear bleeders. Btw, the bleeder doesn't need to be completely removed, just released enough to see the fluid starts to flow. I to don't believe order is really important, start with front wheels, those are the most important. After opening the bleeder, try 'pushing' the caliper with your hands (eventually remove the retaining clip before). This way you will fully empty the old fluid that's inside the caliper piston. If you bleed 1/4 of the bottle at each wheel it should be fine. Oil reservoir without the cap and continuously checking so the level doesn't drop behind the min (important). Preferably don't depress the brake pedal, even if the fluid will be very slow to leak.
A good tip, once a bleeder is loosen, 'twist' it a couple of times until you feel it's easy to turn - this will remove all rust around the threads. No need to over tighten the bleeder.
Old Sep 15, 2014 | 01:42 PM
Sherry007's Avatar
Thanks oragex for valuable info.
What exactly do you mean "Don't depress the brake pedal" ???
and what if do not want to push the calipers as I know it is kind a hard to taking them off.
finally, can I change the fluid one by one like...if I change LF today and will change FR after few days ??? Is there any issue?
Old Sep 20, 2014 | 09:18 AM
kalali's Avatar
The idea is to start with the caliper furthest from the reservoir and work you way to the front, the last usually being the driver side front.
Old Sep 20, 2014 | 12:05 PM
ES6T's Avatar
I understand the idea behind it. But Volvos procedure actually states the opposite.
Old Sep 21, 2014 | 12:53 PM
majorcode's Avatar
I am also going to change brake fluid soon, but will only do front ones. Will start from Right. Hope things will go better.
Stratoblaster
Sep 2, 2024 11:18 AM
robretpd
Mar 19, 2009 07:35 AM
pfc
Nov 3, 2008 08:12 AM
Flying torquewrench
Apr 3, 2006 08:20 PM
