check engine codes
Old Jan 20, 2007 | 06:30 PM
Devilboy304's Avatar
Default check engine codes
Check engine light popped back on, I figured i was sick of paying VOLVO for their service charge so i went out and bought a fairly decent obdii scanner. Hooked it up and pulled the following...
P0354 Ignition Coil primary/secondary circuit
P1152 which i cant find but I believe is an o2 sensor code?
Tech or anyone please offer help on both codes and expenses to fix? or whatnot thanks!
Old Jan 20, 2007 | 06:52 PM
Default RE: check engine codes
Yes 1152 is an O2 sensor code Rear o2 sensor.
Not sure about the coil code I would have to try to find the crossrefrence to be able to tell you.
Thats the only bad thing using the OBDII scanners and the P codes.
I have to have a chart to be able to crossrefrence to Volvo codes.
Old Jan 20, 2007 | 07:32 PM
how urgently would the o2 need to be replaced... I know they can eat up the cat but im thinking that with 120K on a 99 maybe the cat is shot anyways?
Old Jan 24, 2007 | 08:32 PM
You can go a little but I wouldn't go to long.
wieder
Sep 10, 2010 08:42 PM
Bruno937
Mar 25, 2008 08:31 AM
gabyman97596
May 14, 2007 09:52 PM
cranky
Aug 5, 2005 09:46 PM
