on going 2000 S80 T6 problems/issues
Old Apr 27, 2013 | 11:36 PM
rerobin66's Avatar
Default on going 2000 S80 T6 problems/issues
With all the following, can anyone give me an idea as to how much further in this “Volvo S80 T6” tunnel of darkness I might expect to go before I see some light?! What other super common issues might I expect to have? Please share anything I have not listed…..promise I won’t cry.
Repairs made to my Volvo 2000 S80 T6 with 129000 miles
Rear brake pads
Broken fuel pump plastic housing
Squeaky glove box latch
Clunky sunroof glass
Drive axles right and left
Control arms w/bushings
Sway bar links
Turbo boost solenoid
New transmission
Headlight lens right side
Most vacuum hoses due to rot
Maintenance done as follows:
Spark plugs changed
Fuel filter replaced
Transmission filter and fluid twice before replacing transmission
Accessories done as follows:
Custom sheepskin seat covers
Wood grain look dash kit
Leather (wrapped) steering wheel cover
Current issue to address is no oil pressure message, plan of attack is to drop oil pan and replace o-rings and clean tubes, screen, etc.
Old Apr 30, 2013 | 09:44 PM
rerobin66's Avatar
What we found once we dropped the oil pan. A very bad o-ring on the tube to the oil filter housing.
Attached Thumbnails on going 2000 S80 T6 problems/issues-img_20130430_185618_401.jpg
Old May 5, 2013 | 12:27 PM
CPB's Avatar
CPB
Does it leak from the oil filter housing or just creates a lack of oil pressure in the the filter?
Old May 5, 2013 | 09:17 PM
rerobin66's Avatar
it just caused no oil pressure. which triggered the message "no oil pressure stop engine" and after researching that warning through forums we concluded that it might be the oil pump or o-rings. Glad it was the latter.
dobrosailor
Jan 16, 2010 10:21 PM
dobrosailor
Jan 12, 2010 06:20 AM
daver80
Jun 29, 2009 03:01 PM
XSive
Jun 20, 2007 05:15 PM
