Going after it in the morning...
Old Sep 5, 2008 | 05:55 PM
75ohm's Avatar
Default Going after it in the morning...
Front rotors/pads/bearings...
Wish me luck!
75.
Old Sep 5, 2008 | 07:44 PM
nicolaselias's Avatar
Default RE: Going after it in the morning...
goodluck 75, what are you replacing with..
Old Sep 5, 2008 | 10:23 PM
Good luck if you need me you know my e-mail address. I will be home most of the day.
Old Sep 6, 2008 | 08:24 AM
75ohm's Avatar
Thanks guys... front rotors are being replaced with brembos and akebono ceramic pads. Hub/bearing assemblies by ***. Parts from FCP Groton.
Old Sep 6, 2008 | 09:53 AM
75ohm's Avatar
Time check. Start +1.5 hours. Rotors, pads, hubs are off. Going to take a quick break for a drink and start cleaning parts for reassembly.
Old Sep 6, 2008 | 12:12 PM
75ohm's Avatar
I spend too much time cleaning parts... need to put the wheels on and lower and it is done.
Old Sep 6, 2008 | 01:31 PM
Do any of you have an opinion about which rotors are better, the zimmerman or the brembo? Good work about the job, I guess better to take the time cleaning than to have to take everything back down some other time...
Normally, how many miles do you get on a set of the full organic ceramic pads for the s80...
Old Sep 6, 2008 | 02:55 PM
75ohm's Avatar
Brembo is oem for a lot of vehicles; however, I have zimmermans on my other car. They are drilled. The price difference between the brembos and zimmermans did it for me pretty much for the same rotor. As far as the pads go, this will be my first go on the ceramics.
Took the car for a test drive after I got cleaned up. So much nicer of a ride more more smoothe on the ride and the braking now. My wife will be pleased...
Hardly a daunting task a couple of things that could get you though...
Old Sep 6, 2008 | 05:43 PM
Glad all went smooth for you.
Old Sep 7, 2008 | 08:18 AM
75ohm's Avatar
Thanks for the support Tech!
Old Sep 7, 2008 | 10:38 AM
NP anytime.
mtatro
May 26, 2012 11:11 PM
dobrosailor
Jan 16, 2010 10:21 PM
dobrosailor
Jan 12, 2010 06:20 AM
daver80
Jun 29, 2009 03:01 PM
XSive
Jun 20, 2007 05:15 PM
