Headlight fail 2009 S80 3.2
Old Dec 29, 2018 | 04:51 PM
ptvolvo2's Avatar
Default Headlight fail 2009 S80 3.2
Hi All. Just joined the forum because I am having a hard time with my driver's side low beam headlight. Passenger's side works fine. I've tried two new bulbs but neither of those works either. I suspected a fuse problem, but am unable to locate a fuse for this circuit (if there even is one). Before 2007 there were fuses for right and left side low beams in a fuse box on the left side of the dashboard assembly, accessible by opening the door. But this car does not have a fuse panel there, and the one now located below the glove box does not have fuses for the headlights. Neither do the fuse boxes under the hood or the three boxes in the trunk. Is there no fuse? What do you folks think might be going on. Thanks very much. Phil
Old Jan 20, 2019 | 03:42 PM
Bump.
tenchu
Nov 5, 2020 09:34 AM
ptvolvo2
Jan 20, 2019 03:42 PM
alan - flitwick
Apr 14, 2009 11:04 PM
arapchoge1
May 11, 2007 09:02 AM
Sssnake
Jul 18, 2005 03:37 AM
