How to change-out heater core
Old Aug 28, 2008 | 10:54 AM
rvinson2's Avatar
Default How to change-out heater core
I need to swap out the heater core in my 99 S-80. what do I need to know? What is the procedure and are there any tricks or pitfalls?
Old Sep 3, 2008 | 08:13 PM
Xrious's Avatar
Default RE: How to change-out heater core
on my 2000 T6 I ended up pulling the entire dash out, it wasn't that hard, just time consuming. try to get the instruction off VADIS as they helped. Mkae sure you remember exactly where each screw/bolt comes from.
You 'might' be able to pull out the core from the left had side footwell, but when I tried it was too tight (Mines a right hand drive)
Be very very careful when you take the steering wheel off. Make sure your wheels are pointing straight ahead, make sure the steering wheel is level and lock off the contact wheel. I didn't and mine broke. Got an airbag light, and traction control (steering wheel angle sensor error) There are no bumps stops on the contact reel so if it goes to an end, you've just broken it.
If you're leak is just in the left hand side, it might be the o-rings for the pipes. deffinately worth replacing first as it'll save you many hours work.
Stu
Old Sep 3, 2008 | 08:22 PM
The left hand drive you can slide it out without pulling the dash.
Old Sep 3, 2008 | 08:37 PM
Xrious's Avatar
Really? damm, now I'm very jealous. That would have saved me many hours of work.
Stu
johnnyb_s
Dec 14, 2018 01:52 AM
ycartf
May 6, 2013 11:19 AM
HeadDragon
Jan 1, 2013 09:19 PM
Bruce Wayne
Mar 25, 2009 09:19 PM
azeezn
Dec 12, 2005 10:50 PM
