How do I figure out this message?
Old Aug 24, 2007 | 12:44 AM
cnjsommers's Avatar
Default How do I figure out this message?
I have a 2000 S80 and the computer always has the caution light on and sais "bulb failure positon light" does anyone know what that could be? as far as I can see every light I can see works just fine. all the bulbs are functioning. can I reset the light and if so how?
thanks
Old Aug 24, 2007 | 12:49 AM
E_S80's Avatar
Default RE: How do I figure out this message?
It's one of the all-time rear running lights. Check the three bulbs in each of the taillights on the car and one of 'em should be out.
To replace them, open your trunk and twist the **** on the side and pull open the cover. Then just replace the bulb, I think you have to squeeze some clips to get to the bulbs.
Old Aug 24, 2007 | 10:21 AM
master_pre's Avatar
The bulbs are very inexpensive. While I was in there I replaced all of the bulbs for the rear, it cost me a total of $15 and now all of my bulbs are good for another 7 years or so.
Old Aug 24, 2007 | 11:35 AM
EuroDriverSD's Avatar
I would suggest getting the bulbs directly from the stealer (i.e., the dealer). First time I had a bulb go out I replaced it 3X to no avail. I ended up buying the whole bulb socket housing for the taillight & it wasn't until then that I realized the car doesn't like the Sylvania bulbs from Autozone. I tested this theory a couple more times with consistent (yet intermittent) results. However, the Sylvania Silverstarsfor the parking lights work fine.
Old Aug 24, 2007 | 06:09 PM
master_pre's Avatar
I'm using Sylvannia bulbs from Autozone and they worked fine from the get go!
Old Aug 24, 2007 | 10:17 PM
01_fast_ride's Avatar
I stocked up on the Sylvanias. Got a box of 10 for a quarter. Yup 2.5cents each. I should have grabbed every box the store had, but what are ya gonna do with 300 taillight bulbs? [8D]
Old Aug 25, 2007 | 04:04 PM
master_pre's Avatar
2.5 cents a bulb!!! Damn that's a good deal.
Old Aug 31, 2007 | 06:18 PM
go2sharks's Avatar
ORIGINAL: cnjsommers
thanks
Don't forget the license plate lights.
renejuan
Oct 21, 2008 09:32 PM
tarun90
Dec 30, 2007 10:32 AM
jorhyne
Oct 20, 2007 06:31 PM
bigdaddyrdpjr
Sep 9, 2007 10:30 PM
MattB850in
Mar 21, 2007 12:52 PM
