intial start up.
Old Aug 27, 2006 | 01:56 AM
gordon368's Avatar
Default intial start up.
I dont know if this is normal, but here goes(01 S80 t6) ...
At the initial start up, the car's rpm's fluctuate for like 10 seconds (it bobbles, coughes, and vibrates decent amount), In my dads car-fresh start up none of that fluctuating(he has a nissan altima 05). Also i usually wait till the engine heat meter comes up to the first bar and i start to drive it, even with slow acceleration it will not be able to slowly accelerate smoothly, it will sorta surge then come back down, and im just steadily and slowly accelerating.
Also I hear a loud whistling sound. This is at the first bar of the engine heat meter. when it gets half way(the engine's heat meter) it accelerates normal, and the whistling sound is gone.
Are these normal things from this car?
Old Aug 27, 2006 | 04:30 AM
Bboble's Avatar
Default RE: intial start up.
I have the same exact problem, I also have a check engine light, and the code is for running rich in one of the banks. I believe it must be a coolant temp sensor, and plan on looking at it tommorow. Does anyone know where the sensor is located, and is there any test that can be preformed with a multimeter, to see if it is faulty?
TIA
Old Aug 27, 2006 | 12:23 PM
Could be a faulty coolant temp sensor.
On some of the cars the sensor and thermostat are located by the Upper Radiator hose.
On the others it is located on the front of the engine under the timing cover.
It could also be many other things.
Old Aug 27, 2006 | 04:04 PM
gordon368's Avatar
all that goes away when the car fully warms up, that could still be a faulty coolant sensor? Shouldnt the car give me like a Check engine light? What are some of the other things it could be?
Old Aug 28, 2006 | 08:41 PM
Yes could still be a coolant temp sensor and not throw codes.
Bad fuel pump (Bleeds back when sitting for a while)
ETM problems.
Old Aug 29, 2006 | 12:27 PM
gordon368's Avatar
could we cross of etm, since mine was done under warranty, or it could still be the etm?-done like 2 months ago.
Old Aug 29, 2006 | 08:49 PM
OK Cross it off.
DecalService
Dec 4, 2019 10:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
WagHag
Dec 2, 2007 08:45 AM
auser
Nov 20, 2004 10:27 AM
